DAcreate2d process layout order
Fri May 19 07:53:16 CDT 2006
Ok, so it is laid-out like a matrix, not like x, y coordinates.
Will put the change to DA on the list of things to do.
    Barry
On Thu, 18 May 2006, Sean Dettrick wrote:
> Barry Smith wrote:
>> Bill, does the MPI standard dictate this decomposition or
>> could different implementations do it the opposite way?
>> Then we'd have to make the DA logic a bit more complicated.
> I don't have a copy of the standard, but to quote page 255 of "MPI, the
> complete reference" by Snir et al:
> "Row-major numbering is always used for the processes in a Cartesian
> structure".
> Their diagram in figure 6.1 matches my code output for coords couplets (i,j):
> 0      1       2       3
> (0,0)  (0,1)   (0,2)   (0,3)
> 4      5       6       7
> (1,0)  (1,1)   (1,2)   (1,3)
> 8      9      10      11
> (2,0)  (2,1)   (2,2)   (2,3)
> By the way I agree with you, I *should* be able to swap the x and y myself.
> Just haven't had much luck yet in that regard.
> Sean
>>>>> Hi Barry,
>>>>> the order is determined by MPI_Cart_create.
>>>>    Do you mean that MPI_Cart_create() orders across the 2nd (y-axis)
>>>> fastest and then the first (x-axis)? Hmmm, maybe we should change the
>>>> DA? Changing it once and for all (not supporting both) is probably
>>>> not a big deal and shouldn't break much (I hope).
>>> Hi Barry,
>>> it depends, what do you call x and what do you call y?
>>> MPI_Cart_coords returns a vector, coords - I tend to say x is coords[0], y
>>> is coords[1] and z is coords[2]. For what it's worth, there's a short code
>>> appended to this email, which produces:
>>> rank = 0 has Cartesian coords = { 0, 0 }
>>> rank = 1 has Cartesian coords = { 0, 1 }
>>> rank = 2 has Cartesian coords = { 1, 0 }
>>> rank = 3 has Cartesian coords = { 1, 1 }
>>> rank = 0 has DA range x=[0,50) and y=[0,50)
>>> rank = 1 has DA range x=[50,100) and y=[0,50)
>>> rank = 2 has DA range x=[0,50) and y=[50,100)
>>> rank = 3 has DA range x=[50,100) and y=[50,100)
>>>>>>    I don't completely understand what goes wrong. Is it because YOUR
>>>>>> application orders the processors related to geometry in the following
>>>>>> way?
>>>>>>     ^ y direction
>>>>>>        2   5  8
>>>>>>        1   4  7
>>>>>>        0   3  6
>>>>>>                     -> x direction
>>>>>> Or is this something inherent in MPI_Cart_create?
>>> For my interpretation of x and y, MPI_Cart_create produces the above
>>> layout. But if I said x=coords[1] and y=coords[0], then it would match the
>>> one below.
>>>>>> PETSc does it so
>>>>>>     ^ y direction
>>>>>>        6   7  8
>>>>>>        3   4  5
>>>>>>        0   1  2
>>>>>>                     -> x direction
>>> Code and makefile attached ... hopefully within the message size limit.
>>> Just make cartcommtest.
>>> Sean
