DAcreate2d process layout order
Sean Dettrick sean at trialphaenergy.com
Thu May 18 21:36:13 CDT 2006
Barry Smith wrote:
> On Thu, 18 May 2006, Sean Dettrick wrote:
>> Hi Barry,
>> the order is determined by MPI_Cart_create.
>    Do you mean that MPI_Cart_create() orders across the 2nd (y-axis)
> fastest and then the first (x-axis)? Hmmm, maybe we should change the
> DA? Changing it once and for all (not supporting both) is probably
> not a big deal and shouldn't break much (I hope).
Hi Barry,
it depends, what do you call x and what do you call y?
MPI_Cart_coords returns a vector, coords - I tend to say x is coords[0],
y is coords[1] and z is coords[2].
For what it's worth, there's a short code appended to this email, which
produces:
rank = 0 has Cartesian coords = { 0, 0 }
rank = 1 has Cartesian coords = { 0, 1 }
rank = 2 has Cartesian coords = { 1, 0 }
rank = 3 has Cartesian coords = { 1, 1 }
rank = 0 has DA range x=[0,50) and y=[0,50)
rank = 1 has DA range x=[50,100) and y=[0,50)
rank = 2 has DA range x=[0,50) and y=[50,100)
rank = 3 has DA range x=[50,100) and y=[50,100)
>>>    I don't completely understand what goes wrong. Is it because YOUR
>>> application orders the processors related to geometry in the
>>> following way?
>>>     ^ y direction
>>>        2   5  8
>>>        1   4  7
>>>        0   3  6
>>>                     -> x direction
>>> Or is this something inherent in MPI_Cart_create?
For my interpretation of x and y, MPI_Cart_create produces the above
layout.  But if I said x=coords[1] and y=coords[0], then it would match
the one below.
>>> PETSc does it so
>>>     ^ y direction
>>>        6   7  8
>>>        3   4  5
>>>        0   1  2
>>>                     -> x direction
Code and makefile attached ... hopefully within the message size limit.
Just make cartcommtest.
Sean
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060518/2e8ba5bc/attachment.diff>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060518/2e8ba5bc/attachment.c>
