common nodla points on neighbouring subdomains
Wed May 17 13:43:23 CDT 2006
   Thomas,
     Ok, things are clearer. Are you using the VecCreateGhost() routines?
If you are not using them you should use them (see manual page
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Vec/VecCreateGhost.html)
Once the solver is done you will call
        VecGhostUpdateBegin(v,INSERT_VALUES,SCATTER_FORWARD);
        VecGhostUpdateEnd(v,INSERT_VALUES,SCATTER_FORWARD);
and use VecGhostGetLocalRepresentation() to access the vector plus its
ghost points. (note that the "local" and "global" representations
share the same data in the same memory, the difference is that the "local"
is a VecSeq (with ghost points at the end) and the "global" is a VecMPI that
is the one actually passed to the solver and used with VecSetValues().
   Good luck,
    Barry
On Wed, 17 May 2006, Thomas Geenen wrote:
> On Wednesday 17 May 2006 14:53, Barry Smith wrote:
>>    Thomas,
>>      I think you might misunderstand the function of XXXSetValuesLocal().
>> What happens with them is the index is mapped to the global index and
>> the value is then put into the "correct" global location, so some values
>> will be shipped off to the "owning" process.
> this happens in the assemble phase right?
>> 1) If two processes that
>> "share" a vertex both generate the entire stiffness for that vertex
>> (that is, each process loops over all the elements containing the
>> vertex summing the stiffness for that vertex) then the result will
>> be exactly twice the expected value (since one process will send the
>> result to the "owning" process). I THINK this is what you are doing.
> I intercept the matrix and rhs just before the "old" call to the solver
> routine just before the call the value for the rhs of common nodalpoints are
> calculated globally and broadcasted to the owning processes. In this setup
> more than one process can own a nodal point. I construct a local2global
> mapping and apply it to the matrix and vector
> ISLocalToGlobalMapping ltog;
> ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, nc, local2global, &ltog);
> MatSetLocalToGlobalMapping(A, ltog);
>> 2) if, on the other hand, each process generates only the part of the
>> stiffness for the vertex from elements that it "owns" then the global
>> matrix will be correct, BUT the communication of matrix elements to the
>> "owning" process is done. If you DO NOT want the communication to the
>> owning process but want to keep part of the stiffness on each process (for
>> a shared vertex) I would call this the unassembled form. This is done by
>> some people but is not really supported by PETSc.
>> I think you may want to consider NOT having "shared" vertices (that is
>> either 1 if you are using that or 2). This may not require much change to
>> what you do not want to change but will allow you to easily use all of the
>> PETSc solvers. The problem with "unassembled" approaches is that they save
>> a bit of communication in generating the stiffness but then (since the
>> matrix is never assembled) cannot form much of anything in terms of
>> preconditioners, thus you do lots of linear solver iterations with
>> communication. Communicating the stiffness initially (if you have a good
>> partitioning of elements) is really not much communication and IMHO is the
>> wrong place to optimize.
> basically what happens in my code is that each process owns all nodalpoints of
> the element it owns. I tell petsc the global numbering of the matrix and
> vector entries so I can use all the preconditioners and solvers etc. However
> in the original setup the program expects on return to have the solution
> vector for all nodes of the elements it owns . Petsc gives the solution to
> the "owner process" of the nodal point. To correct this I would have to send
> parts of the solution to processes that don't "own" that part of the solution
> but do expect it to be there. I thought It would be elegant if Petsc could
> return a solution vector that corresponds to the local filling of the vector
> not to the "owners" of the nodal point.
> thanks for you fast response
> Thomas Geenen
>>    I hope my response is not too confusing, I may have misunderstood
>> parts of your question.
>>     Barry
>>> Dear Petsc users,
>>> I am solving a system of equations Ax=b resulting from a Finite element
>>> package.  The parallelization strategy for this program is to minimize
>>> communication. therefore each subdomain has its own copy of common nodal
>>> points between subdomains (local numbering). This strategy is already
>>> implemented and I don't want to change that
>>> I fill the matrix and right hand side with a call to MatSetValuesLocal
>>> and VecSetValuesLocal. Some entries are filled on different subdomains
>>> (of course with the same value)
>>> The solution for the first subdomain is correct. however the solution
>>> vector on the second subdomain does not contain the solution on the
>>> common nodal points it shares with subdomain 1.
>>> This is probably a feature but it is not consistent with my program
>>> setup. The question is:
>>> how can i tell petsc to return a solution for all the positions i filled
>>> with VecSetValuesLocal?
>>> Thanks in advance
>>> Thomas Geenen
>>> ps I got the impression that the assemble routines also exchange common
>>> nodal point info.  It would be nice if this could be skipped as well.
>>> Of course some extra communication could solve my problem but I would
>>> prefer a more elegant solution if one exists
