Petsc + BlockSolve95
Boulahya Faïza F.Boulahya at brgm.fr
Wed May 17 05:58:28 CDT 2006
Ok but the error does not come from parallell ICC. It's from the
MatSetOption().
Moreover, when I tried with MATMPIROWBS , it's the same problem :
[0]PETSC ERROR: MatSetOption_MPIRowbs() line 1411 in
src/mat/impls/rowbs/mpi/mpirowbs.c
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: unknown option!
[0]PETSC ERROR: MatSetOption() line 4137 in src/mat/interface/matrix.c
Faïza
-----Message d'origine-----
De : Satish Balay [mailto:balay at mcs.anl.gov]
Envoyé : mardi 16 mai 2006 15:39
À : 'petsc-users at mcs.anl.gov'
Objet : RE: Petsc + BlockSolve95
> [0]PETSC ERROR: MatSetOption_MPIAIJ() line 1251 in
> src/mat/impls/aij/mpi/mpiaij.c [0]PETSC ERROR: No support for this
AIJ matrix does not support parallell ICC. BlockSolve provides parallel ICC
- and to use it one must use MatType MATMPIROWBS
Satish
On Tue, 16 May 2006, Boulahya Faïza wrote:
> Is there something new about it?
> De : Vaz, Guilherme [mailto:G.Vaz at marin.nl]
> I have exactly the same problem as Faiza...
> In sequential it runs ok but in parallel not.
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov]
> On Behalf Of Boulahya Faïza
>  I tried something else :
>     - creation of the matrix with MatCreateMPIAIJ
>     - initialization
>     - adding of the options MAT_SYMMETRIC and MAT_SYMMETRY_ETERNAL
> When solving in sequential CG + ICC, everything is ok. When I tried in
> parallel the same code the options lead to the same error :
> Can MatSetOption be only used in sequential?
> Faïza
>   _____
> De : Matthew Knepley [mailto:knepley at gmail.com] Envoyé : mardi 9 mai
> 2006 18:19 À : petsc-users at mcs.anl.gov Objet : Re: Petsc +
> BlockSolve95
> I believe there is a problem with the option that you specified. All
> these are integers, and it is complaining that the integer does not
> match MAT_SYMMETRIC. I will fix the error message to print the
> offending option, but please check the code.
>   Thanks,
>      Matt
> On 5/9/06, Boulahya Faïza <F.Boulahya at brgm.fr
> <mailto:F.Boulahya at brgm.fr> >
> wrote:
> Hi All,
> Has anyone used Conjugate Gradient Solver + Icomplete Cholesky
> Preconditionner in parallel case? I tried as said in the manual : I
> use MATMPIROWBS for the storage of the matrice. However I get this message
> PETSC ERROR: To use incomplete Cholesky
>                         preconditioning with a MATMPIROWBS matrix you
> must declare it to be
>                         symmetric using the option
> MatSetOption(A,MAT_SYMMETRIC)!
> So I tried adding this option (even if in the namual it is written
> that it is not required). Then I obtained this message
> In advance thanks,
> Faïza
> Pensez à visiter le site BRGM sur.... http://www.brgm.fr/
> Le contenu de cet e-mail et de ses pièces jointes est destiné à
> l'usage exclusif du
> (des) destinataire(s) expressément désigné(s) comme tel(s). En cas de
> réception de cet  e-mail par erreur, le signaler à son expéditeur et
> ne pas en divulguer le contenu.
> L'absence de virus a été vérifié à  l'émission du message. Il convient
> néanmoins de vérifier l'absence de corruption à sa réception.
> The contents of this email and any attachments are confidential. They
> are intended for the named recipient(s) only. If you have received
> this email in error please notify the system manager or  the sender
> immediately and do not disclose the contents to anyone or make copies.
> eSafe scanned this email for viruses, vandals and malicious content.
> l'usage exclusif du
> réception de cet  e-mail par erreur, le signaler à son expéditeur et ne
Le contenu de cet e-mail et de ses pièces jointes est destiné à l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de cet
 e-mail par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifié à  l'émission du message. Il convient néanmoins de
The contents of this email and any attachments are confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or  the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060517/3bb20731/attachment.htm>
