Petsc + BlockSolve95
Hong Zhang hzhang at mcs.anl.gov
Wed May 10 09:43:23 CDT 2006
I reproduced this crash and am working on it.
Hong
On Wed, 10 May 2006, Barry Smith wrote:
>    Hmm, can anyone reproduce this in the debugger? What is the value
> of op in MatSetOption_MPIAIJ() that is not accepted?
>    Is this also Fortran?
>     Barry
> BTW: I have updated petsc-dev to print the numerical value of any
> op that it claims is "unknown", instead of providing NO useful information
> like it use to.
> On Wed, 10 May 2006, Vaz, Guilherme wrote:
> > Hello people,
> > I have exactly the same problem as Faiza...
> > In sequential it runs ok but in parallel not.
> > Greetings.
> > Guilherme
> > -----Original Message-----
> > From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Boulahya Faïza
> > Sent: 10 May 2006 10:39
> > To: 'petsc-users at mcs.anl.gov'
> > Subject: RE: Petsc + BlockSolve95
> > Thanks.
> > I tried something else :
> >    - creation of the matrix with MatCreateMPIAIJ
> >    - initialization
> >    - adding of the options MAT_SYMMETRIC and MAT_SYMMETRY_ETERNAL
> > When solving in sequential CG + ICC, everything is ok. When I tried in parallel the same code the options lead to the same error :
> > [0]PETSC ERROR: MatSetOption_MPIAIJ() line 1251 in src/mat/impls/aij/mpi/mpiaij.c
> > [0]PETSC ERROR: No support for this operation for this object type!
> > [0]PETSC ERROR: unknown option!
> > [0]PETSC ERROR: MatSetOption() line 4137 in src/mat/interface/matrix.c
> > Can MatSetOption be only used in sequential?
> > Faïza
> > ________________________________
> > De : Matthew Knepley [mailto:knepley at gmail.com]
> > Envoyé : mardi 9 mai 2006 18:19
> > À : petsc-users at mcs.anl.gov
> > Objet : Re: Petsc + BlockSolve95
> > I believe there is a problem with the option that you specified. All these
> > are integers, and it is complaining that the integer does not match
> > MAT_SYMMETRIC. I will fix the error message to print the offending
> > option, but please check the code.
> >  Thanks,
> >     Matt
> > On 5/9/06, Boulahya Faïza <F.Boulahya at brgm.fr> wrote:
> > Hi All,
> > Has anyone used Conjugate Gradient Solver + Icomplete Cholesky Preconditionner in parallel case? I tried as said in the manual : I use MATMPIROWBS for the storage of the matrice. However I get this message :
> > PETSC ERROR: To use incomplete Cholesky
> >                        preconditioning with a MATMPIROWBS matrix you must declare it to be
> >                        symmetric using the option MatSetOption(A,MAT_SYMMETRIC)!
> > So I tried adding this option (even if in the namual it is written that it is not required). Then I obtained this message
> > PETSC ERROR: MatSetOption_MPIRowbs() line 1411 in src/mat/impls/rowbs/mpi/mpirowbs.c
> > In advance thanks,
> > Faïza
> > Pensez à visiter le site BRGM sur.... http://www.brgm.fr/
> > Le contenu de cet e-mail et de ses pièces jointes est destiné à l'usage exclusif du
> > (des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de cet
> > e-mail par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
> > L'absence de virus a été vérifié à  l'émission du message. Il convient néanmoins de
> > vérifier l'absence de corruption à sa réception.
> > The contents of this email and any attachments are confidential. They are intended for
> > the named recipient(s) only. If you have received this email in error please notify the
> > system manager or  the sender immediately and do not disclose the contents to
> > anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
> > content.
