Petsc + BlockSolve95
Tue May 9 11:19:19 CDT 2006
I believe there is a problem with the option that you specified. All these
are integers, and it is complaining that the integer does not match
MAT_SYMMETRIC. I will fix the error message to print the offending
option, but please check the code.
     Matt
On 5/9/06, Boulahya Faïza <F.Boulahya at brgm.fr> wrote:
> Hi All,
> Has anyone used Conjugate Gradient Solver + Icomplete Cholesky
> Preconditionner in parallel case? I tried as said in the manual : I use
> MATMPIROWBS for the storage of the matrice. However I get this message :
> PETSC ERROR: To use incomplete Cholesky
>                         preconditioning with a MATMPIROWBS matrix you must
> declare it to be
>                         symmetric using the option
> MatSetOption(A,MAT_SYMMETRIC)!
> So I tried adding this option (even if in the namual it is written that it
> is not required). Then I obtained this message
> PETSC ERROR: MatSetOption_MPIRowbs() line 1411 in
> src/mat/impls/rowbs/mpi/mpirowbs.c
> PETSC ERROR: No support for this operation for this object type!
> PETSC ERROR: unknown option!
> PETSC ERROR: MatSetOption() line 4137 in src/mat/interface/matrix.c
> In advance thanks,
> Faïza
> Pensez à visiter le site BRGM sur.... http://www.brgm.fr/
> Le contenu de cet e-mail et de ses pièces jointes est destiné à l'usage exclusif du
> (des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de cet
>  e-mail par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
> L'absence de virus a été vérifié à  l'émission du message. Il convient néanmoins de
> vérifier l'absence de corruption à sa réception.
> The contents of this email and any attachments are confidential. They are intended for
> the named recipient(s) only. If you have received this email in error please notify the
> system manager or  the sender immediately and do not disclose the contents to
> anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
> content.
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060509/0c35c43a/attachment.htm>
