nullspaces
Tue May 9 08:35:35 CDT 2006
On 5/9/06, Yaron Kretchmer <yaronkretchmer at gmail.com> wrote:
> Hi all
> I have a matrix representing electrical currents (KCL). In my design,
> there are some elements which are totally isolated from the rest of the
> circuit, which means that they form the matrix's nullspace.
> My questions are:
> *) Can I use Petsc to derive the nodes which compose the nullspace
We do not have QR type algorithms in PETSc, but you could use LAPACK or
PLAPACK for dense matrices.
*) Can I then remove them from the KSP? If so, how?
You can use the MatNullSpace architecture to remove these components from a
solve.
    Matt
Thanks much
> Yaron
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060509/02fb298a/attachment.htm>
