memory bleeding
Jordi Marcé Nogué jordi.marce at upc.edu
Mon May 8 05:10:07 CDT 2006
Thanks Barry,
I'm using petsc 2.2.0. When I run my program ( " ./myprogram -trdump " or with
-trmalloc, -trinfo...) I don't obtain anything... in the screen the code doesn't
print
anything.
If I use (for example) "./myprogram -start_on_debugger", in my screen apers gdb
and runs good... and with another options like -log_trace petsc writes messages
in
my screen. Would I have to activate something in my internal petsc code?
best regards,
jordi
Missatge citat per Barry Smith <bsmith at mcs.anl.gov>:
>     See
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> number 12
>     You can run for say a few iterations with the options
> -malloc_debug -malloc_dump (in  PETSc 2.3.1. in early releases it had
> different names). At PetscFinalize() PETSc will print all the memory
> it has allocated that has not been freed and where it was allocated.
> This can help determine what objects are not being freed.
>     Barry
> > Hi,
> > I use PETSc, and after 5000 (more or less) iteations in which i solve a
> little
> > matrix
> > (30x30) my swap is totally used!!! I'm sure that when I create my matrices
> I
> > destroy
> > them. Could you help me about it? What happens? What thing I do bad?
> > Mat K
> > MatCreateSeqAIJ(PETSC_COMM_SELF, dim, dim, 9 , PETSC_NULL, &K);
> > MatSetFromOptions(K);
> > MatSetOption(K, MAT_SYMMETRIC);
> > MatSetOption(K, MAT_ROW_ORIENTED);
> > MatSetOption(K, MAT_IGNORE_ZERO_ENTRIES);
> > MatSetOption(K, MAT_NEW_NONZERO_ALLOCATION_ERR);
> > ( I use KSP solve, created and destroyed)
> > MatDestroy(K);
> > Thanks,
> > jordi
> > Jordi Marcé-Nogué
> > Dept. Resistència de Materials i Estructures a l'Enginyeria
> > Universitat Politècnica de Catalunya (UPC)
> > Edifici T45 - despatx 137
> > ETSEIAT (Terrassa)
> > phone: +34 937 398 728
> > mail: jordi.marce at upc.edu
