On entry to DGEMV parameter number 6 had an illegal value
Fri Jun 9 10:36:06 CDT 2006
Okay, first this probably happens because the Fortran string handling
in the BLAS library is different from PETSc. This is probably because
they were compiled with different Fortran compilers. The solution is
usually to use --download-f-blaslapack in configure.
However, configure should catch this error. Can you send me the
configure.log?
     Matt
On 6/9/06, Jordi Marcé Nogué <jordi.marce at upc.edu> wrote:
> Ups! I've forgotten.
> This happens in the line "KSPSolve(solve);"
> En/na owner-petsc-users at mcs.anl.gov ha escrit:
> > Hi!
> > When I'm running my code in the screen appears this message: "** On
> > entry to DGEMV  parameter number  6 had an illegal value"
> > I've tried to find information in internet but I haven't found a link
> > which apperas this message and a PetsC information. Is this problem from
> > PetsC? What's happens?
> > Thanks,
> > jordi
> Jordi Marcé-Nogué
> Dept. Resistència de Materials i Estructures a l'Enginyeria
> Universitat Politècnica de Catalunya (UPC)
> Edifici T45 - despatx 137
> ETSEIAT (Terrassa)
> phone: +34 937 398 728
> mail: jordi.marce at upc.edu
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060609/f5538862/attachment.htm>
