link with other libraries
Fri Jul 21 13:55:25 CDT 2006
   Jordi,
     If you want to provide the rules to compile your code you
can instead just include bmake/common/variables this sets the variables
like ${PETSC_KSP_LIB} but you provide the rules for compiling.
   Satish,
    Do we have written down somewhere on the website for the two
ways of using PETSc makefiles? There should be the directions (that only
you know :-). Maybe in the FAQ?
    Barry
On Fri, 21 Jul 2006, jordi poblet wrote:
> Satish,
> Thank you very much for your fast response. It has solved the problem with
> including files and I can generate the object file for my class (myclass.o).
> However, I suppose that with
> ex1: myclass.o chkopts
> -${CLINKER} -o ex1 myclass.o  ${MY_LIB} ${PETSC_KSP_LIB}
>  ${RM} myclass.o
> the makefile is trying to link a self executable program (ex1) and I
> obtain the following error message:
> : undefined reference to `main'
> (in myclass.cpp there is no main block, the class is used by main.cpp).
> I would like,
> 1-compile the class and obtain the file myclass.o (now I can do it with the
> error shown above, but the file is at least generated) taking into account
> the correct includes (from PETSc and from other libraries). I do not need
> the libraries in this step
> 2-compile all the other classes not using PETSc and obtain the other files
> *.o
> 3-link all the files *.o and myclass.o taking into account all the libraries
> Thank you very much. Best regards,
> Jordi Poblet
> On 7/21/06, Satish Balay <balay at mcs.anl.gov> wrote:
>> The basic form of a PETSc makefile is as follows:
>> CFLAGS           =
>> FFLAGS           =
>> CPPFLAGS         =
>> FPPFLAGS         =
>> CLEANFILES       =
>> include ${PETSC_DIR}/bmake/common/base
>> ex1: ex1.o  chkopts
>>         -${CLINKER} -o ex1 ex1.o  ${PETSC_KSP_LIB}
>>         ${RM} ex1.o
>> If you wish to specify additonal libraries - you can do it as:
>> MY_INC          = -I/my/include
>> MY_LIB          = -L/my/lib -lmy
>> CFLAGS           =
>> FFLAGS           =
>> CPPFLAGS         = ${MY_INC}
>> FPPFLAGS         =
>> CLEANFILES       =
>> ex1: ex1.o  chkopts
>>         -${CLINKER} -o ex1 ex1.o  ${MY_LIB} ${PETSC_KSP_LIB}
>>         ${RM} ex1.o
>> Also - you should make sure this library is compiled with the same
>> compilers as PETSc is compiled with.
>> Satish
>> > Dear all,
>> > I would like to use PETSc within a finite element program (the main part
>> is
>> > written in C++). Some classes should use PETSc routines and routines
>> from
>> > other libraries. When compiling these classes, I have to include not
>> only
>> > the header files from PETSc (which in the examples of a single C or C++
>> > files are included automatically with the sample makefiles provided in
>> the
>> > manual) but also header files from the other used libraries. Finally, I
>> > would have also to link PETSc with other libraries at the same time.
>> > I have tried to construct a makefile including 'by hand' the PETSc
>> headers
>> > but I have always problems. Could someone help me? Have you got makefile
>> > examples for this situation (or similar)?
>> > The compilation options for the PETSc library that I have employed are:
>> > ./config/configure.py --with-mpi=0 --with-clanguage=c++
>> > --with-scalar-type=complex
>> > tests and examples are passed correctly.
>> > I am running PETSc in linux machines.
>> > Thank you in advance,
>> > Jordi Poblet
