distributed array
Berend van Wachem berend at chalmers.se
Thu Jul 20 13:21:36 CDT 2006
Hi Mat,
I understand it's confusing in the beginning - it took me a while to
grasp it as well.
> So what i was thinking was to create a DA and a local sequential vector on each
> subblock (and here i would specify m=n=1 since the local Seqvector/DA resides
> only on one proc, which would give me multiple Seqvectors/DA per processor), and
> then as you say, somehow glue together the "super"-vector (the global vector)
> ... :). Though that is the part which am i stuck on right now.
 > Why did you have to create a communicator for each subblock?
If everything is balanced and the blocks have the same size, you could
specify m=n=1, but you would still need to make a seperate communicator
for each of the blocks; how would the DA otherwise know on which
processor it lies on? I created the communicators with
    ierr = MPI_Comm_group(PETSC_COMM_WORLD, &tmpGroup);
     CHKERRQ(ierr);
     for (i = 0; i < Mesh->TOTBlocks; i++)
         ierr = MPI_Group_incl(tmpGroup, Mesh->CFDParBlocks[i].NProc,
Mesh->CFDParBlocks[i].Proclist, &Mesh->CFDParBlocks[i].BlockGroup);
         CHKERRQ(ierr);
         ierr = MPI_Comm_create(PETSC_COMM_WORLD,
Mesh->CFDParBlocks[i].BlockGroup, &(Mesh->CFDParBlocks[i].BlockComm));
         CHKERRQ(ierr);
Another tip on communicators. Why it is also convenient to have a
communicator for one processor is for data processing from file. For
instance, I have the initial data in one file. I make a DA, similar to
the DA I want to use later on, but for just one processor. I read the
data, and then save the DA to disk. Then I make the real DA with the
communicator and the number of processors I want to have and use DALoad
to read the DA - and all the data is transferred to the appropriate
processor.
 > Do you create an MPI vector for your global vector?
Yes - because  I want to get a solution over the COMPLETE problem in one
matrix. If your blocks are in any way connected, you will want to do
this as well.
"Glueing" the DA vectors into one big one is not difficult if you use
the length of the various DA vectors and glue them together (see code I
sent in previous email)
One thing you also have to think about is cross-block-addressing. One
point in one block has a neighbour it is dependent upon in another
block. In the code I sent you, this addressjump is called "daoffset" and
is member of the block structure (I am an old C++ programmer so I use
mostly structures).
> Sorry for pestering you again, but since you are in Sweden (or your email is
> anyway) i think i might not get you again today ... :)
No problem - just ask. It took me a while before I understood it and the
best thing is to look at examples that come with petsc and maybe the
code examples I send you, please let me know if you want me to send more.
Good luck,
Berend.
> thanks for all your help
> mat
> Quoting Berend van Wachem <berend at chalmers.se>:
>>Hi Matt,
>>Yes, I create a DA for each domain (block I call it in the code) where M
>>and M and N are the dimensions of that block.
>>In my problem I do specify m and n, by a simple algorithm; I try to find
>>a solution so that each processor has about the same number of nodes in
>>total. I do this by taking the first block, looking at how much
>>processors it would get (by dividing its number of nodes by the total
>>number of nodes times the number of processors) and fill it up from
>>that. For each block I create a seperate communicator as well, so each
>>block has its own communicator.
>> From the vectors of the various blocks I glue together one larger
>>vector on which the computations are done, with these functions,
>>#undef __FUNCT__
>>#define __FUNCT__ "VecOverGlobalToBlockGlobalBegin"
>>int VecOverGlobalToBlockGlobalBegin(Vec* A, Vec** B, char *name, struct
>>CFDMesh *Mesh)
>>    int ierr,i;
>>    double *GPtr;
>>    PetscFunctionBegin;
>>    ierr=VecGetArray(*A,&GPtr); CHKERRQ(ierr);
>>    AddToListofLocalVectors(&Mesh->BGCC,Mesh->NMyBlocks,B,GPtr,name);
>>    for (i=0; i<Mesh->NMyBlocks; i++)
>>       ierr=DAGetGlobalVector(Mesh->CFDBlocks[i].da,&((*B)[i]));
>>CHKERRQ(ierr);
>>       ierr=VecPlaceArray((*B)[i], GPtr+Mesh->CFDBlocks[i].daoffset);
>>       CHKERRQ(ierr);
>>    PetscFunctionReturn(0);
>>#undef __FUNCT__
>>#define __FUNCT__ "VecOverGlobalToBlockGlobalEnd"
>>int VecOverGlobalToBlockGlobalEnd(Vec* A, Vec** B, struct CFDMesh *Mesh)
>>       int ierr,i;
>>       double *GPtr;
>>       PetscFunctionBegin;
>>       if (!ExistListOfLocalVectors(Mesh->BGCC,*B,&GPtr))
>>	 ErrorH(1,"Trying to delete a non existing vector from BGCC list");
>>          ierr=VecResetArray((*B)[i]); CHKERRQ(ierr);
>>          ierr=DARestoreGlobalVector(Mesh->CFDBlocks[i].da,&((*B)[i]));
>>CHKERRQ(ierr);
>>       ierr=VecRestoreArray(*A,&GPtr); CHKERRQ(ierr);
>>       DeleteFromListOfLocalVectors(&Mesh->BGCC,*B);
>>>Thanks for the response (and sorry for the late 'thanks'),
>>>i can see how this is supposed to work. However, my question is then with
>>the
>>>creation of the distributed array objects. I take it from your code that
>>you
>>>create a DA for each patch (?). M and N then would be the dimension of my
>>2D
>>>patch. My question is what i would be specifying for n and m. I am a little
>>>confused in general what m and n are. It says they denote the process
>>>partition in each direction and that m*n must be equal the total number of
>>>processes in the communicator.
>>>Sorry, i am almost sure this is something simple.
>>>thanks
>>>mat
>>>On Thursday 13 July 2006 23:13, Berend van Wachem wrote:
>>>>>Hi,
>>>>>i was wondering if it is possible (or advisable) to use a distributed
>>>>array
>>>>>for when my domain is not necessarily rectangular but my subdomains
>>are
>>>>>rectangular?
>>>>>thanks
>>>>>mat
>>>>Hi Matt,
>>>>This is exactly what I do; I work with a multi-block CFD problem, where
>>>>the total geometry consists of a number of structured (not neccesarily
>>>>rectangular) blocks. Each block has its own DA.
>>>>How I solved it, with help from the petsc team, is by making functions
>>>>which translate vectors from the complete domain (called block global in
>>>>my code) to each block (called block local in my code). The matrix
>>>>computation is done at the blockglobal level, and I can manipulate the
>>>>vectors at the block local level. Just to give an example, I attatch the
>>>>code at the end of this email. If you want more help/information please
>>>>let me know.
>>>>Good luck,
>>>>Berend.
>>>>#undef __FUNCT__
>>>>#define __FUNCT__ "VecBlockGlobalToBlockLocalBegin"
>>>>int VecBlockGlobalToBlockLocalBegin(Vec **B, Vec **A, char* name, struct
>>>>CFDMesh *Mesh)
>>>>   int ierr, i;
>>>>   double *tmpPTR=NULL;
>>>>   PetscFunctionBegin;
>>>>   AddToListofLocalVectors(&Mesh->BLCC,Mesh->NMyBlocks,A,tmpPTR,name);
>>>>      ierr=DAGetLocalVector(Mesh->CFDBlocks[i].da, &((*A)[i]));
>>>>CHKERRQ(ierr);
>>>>ierr=DAGlobalToLocalBegin(Mesh->CFDBlocks[i].da,(*B)[i],INSERT_VALUES,(*A)[
>>>>i]); CHKERRQ(ierr);
>>>>ierr=DAGlobalToLocalEnd(Mesh->CFDBlocks[i].da,(*B)[i],INSERT_VALUES,(*A)[i]
>>>>); CHKERRQ(ierr);
>>>>#undef __FUNCT__
>>>>#define __FUNCT__ "VecBlockGlobalToBlockLocalEnd"
>>>>int VecBlockGlobalToBlockLocalEnd(Vec **B, Vec **A, struct CFDMesh
>>>>*Mesh,int CopyData)
>>>>   int i,ierr;
>>>>   PetscFunctionBegin;
>>>>     if (CopyData==MF_COPY_DATA)
>>>>ierr=DALocalToGlobal(Mesh->CFDBlocks[i].da,(*A)[i],INSERT_VALUES,(*B)[i]);
>>>>CHKERRQ(ierr);
>>>>     ierr=DARestoreLocalVector(Mesh->CFDBlocks[i].da,&((*A)[i]));
>>>>CHKERRQ(ierr);
>>>>   DeleteFromListOfLocalVectors(&Mesh->BLCC,*A);
>>   L_@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
>>     | Berend van Wachem                                    |
>>     | Multiphase Flow Group                                |
>>     | Chalmers University of Technology                    |
>>     | Please note that my email address has changed to:    |
>>     | Berend at chalmers.se                                   |
>>     | Please make the appropriate changes in your address  |
>>     | list.                                                |
>>   __@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
>>   \/______________________________________________________/
     | Berend van Wachem                                    |
     | list.                                                |
