I don't find information about this error
Fri Jul 14 07:54:23 CDT 2006
1) The error message is wrong. I fixed this in the dev tree.
2) 'fill' is the fill ratio for speculative allocation. It looks like
    you gave PETSC_DEFAULT which is invalid. You need to
    give a real number (the ratio of the final to initial allocation)
    so it should be > 1.0.
     Matt
On 7/14/06, Jordi Marcé Nogué <jordi.marce at upc.edu> wrote:
> Hello,
> I'm using Petsc 2.3.1 in Debian (updated by apt-get) and I don't find
> information in the web and in the troubleshooting section about this
> error message:
> > [0]PETSC ERROR: MatMatMult() line 6543 in src/mat/interface/matrix.c
> > [0]PETSC ERROR: Nonconforming object sizes!
> > [0]PETSC ERROR: fill=-2 must be > 0.0!
> Maybe you know what does it mean because I've tried a lot of thing in my
> code to solve this problem :-((( My Matrices have the same dimension.
> regards,\j
> Jordi Marcé-Nogué
> Dept. Resistència de Materials i Estructures a l'Enginyeria
> Universitat Politècnica de Catalunya (UPC)
> Edifici T45 - despatx 137
> ETSEIAT (Terrassa)
> phone: +34 937 398 728
> mail: jordi.marce at upc.edu
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060714/f2dc9245/attachment.htm>
