distributed array
Berend van Wachem berend at chalmers.se
Fri Jul 14 00:13:09 CDT 2006
 > Hi,
 > i was wondering if it is possible (or advisable) to use a distributed
array
 > for when my domain is not necessarily rectangular but my subdomains are
 > rectangular?
 > thanks
 > mat
Hi Matt,
This is exactly what I do; I work with a multi-block CFD problem, where
the total geometry consists of a number of structured (not neccesarily
rectangular) blocks. Each block has its own DA.
How I solved it, with help from the petsc team, is by making functions
which translate vectors from the complete domain (called block global in
my code) to each block (called block local in my code). The matrix
computation is done at the blockglobal level, and I can manipulate the
vectors at the block local level. Just to give an example, I attatch the
code at the end of this email. If you want more help/information please
let me know.
Good luck,
Berend.
#undef __FUNCT__
#define __FUNCT__ "VecBlockGlobalToBlockLocalBegin"
int VecBlockGlobalToBlockLocalBegin(Vec **B, Vec **A, char* name, struct
CFDMesh *Mesh)
    int ierr, i;
    double *tmpPTR=NULL;
    PetscFunctionBegin;
    AddToListofLocalVectors(&Mesh->BLCC,Mesh->NMyBlocks,A,tmpPTR,name);
    for (i=0; i<Mesh->NMyBlocks; i++)
       ierr=DAGetLocalVector(Mesh->CFDBlocks[i].da, &((*A)[i]));
CHKERRQ(ierr);
ierr=DAGlobalToLocalBegin(Mesh->CFDBlocks[i].da,(*B)[i],INSERT_VALUES,(*A)[i]);
       CHKERRQ(ierr);
ierr=DAGlobalToLocalEnd(Mesh->CFDBlocks[i].da,(*B)[i],INSERT_VALUES,(*A)[i]);
       CHKERRQ(ierr);
    PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "VecBlockGlobalToBlockLocalEnd"
int VecBlockGlobalToBlockLocalEnd(Vec **B, Vec **A, struct CFDMesh
*Mesh,int CopyData)
    int i,ierr;
    PetscFunctionBegin;
      if (CopyData==MF_COPY_DATA)
ierr=DALocalToGlobal(Mesh->CFDBlocks[i].da,(*A)[i],INSERT_VALUES,(*B)[i]);
CHKERRQ(ierr);
      ierr=DARestoreLocalVector(Mesh->CFDBlocks[i].da,&((*A)[i]));
CHKERRQ(ierr);
    DeleteFromListOfLocalVectors(&Mesh->BLCC,*A);
