PETSC_FILE_* constants missing
Fri Jul 7 09:59:22 CDT 2006
The changelog is a bit brief on this. From:
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/changes/231.html
# PetscViewerFileType changed to PetscFileMode
# PetscViewerSetFileType() changed to PetscViewerFileSetMode()
PETSC_FILE_CREATE, PETSC_FILE_RDONLY etc were  of type PetscViewerFileType
These are replaced with
typedef enum {FILE_MODE_READ, FILE_MODE_WRITE, FILE_MODE_APPEND,
FILE_MODE_UPDATE, FILE_MODE_APPEND_UPDATE} PetscFileMode;
Satish
On Fri, 7 Jul 2006, liu chang wrote:
> Dear all,
> I am a new user of Petsc and have been struggling to install 2.3.1 on
> my workstation. I noticed that in Petsc 2.3.1 I can no longer find the
> definitions of constants PETSC_FILE_CREATE, PETSC_FILE_RDONLY, etc,
> which were in petscviewer.h in version 2.3.0. I looked through the
> changelog and found nothing relevant. What has happened to these
> constants? Some exisiting code uses these constants and I can no
> longer compile them. Any advice?
> Thank you.
> Liu
