AOApplicationToPetscPermute
Thu Jul 6 16:00:45 CDT 2006
AO is not scalable. I am pretty sure this is stated explicitly in the
documentation. We are working on a parallel reordering construct,
but it is not yet finished.
   Matt
On 7/6/06, Laslo Tibor Diosady <diosady at mit.edu> wrote:
> I have an array of values which are in my application ordering and I wish
> to reorder these to the petsc ordering. To do this I use
> AOApplicationToPetscPermuteInt, or PermuteReal, which works really well in
> serial but not so much in parallel.
> In parallel I want to have it so that each processor has it's local
> portion of the array, so that the sum of the lengths of the arrays on each
> processor add up to the sum of the indices in the AO ordering.
> However when I use AOApplicationToPetscPermute I get a segmentation fault,
> which I've traced to the fact that AOApplicationToPetscPermute assumes
> each processor has an array which is the number of indices in the AO
> ordering as opposed to only the length of the local portion of the AO.
> The permutations that I am doing are all local to each processor, but my
> AO has been defined globally since elsewhere in my code I need access to
> off processor entries.
> Do you have any suggestions on how I can solve this problem with the least
> amount of headache.
> Thanks,
> Laslo
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060706/f1dcc5bd/attachment.htm>
