DA Jacobian
Aron Ahmadia aja2111 at columbia.edu
Sun Dec 10 21:16:13 CST 2006
Dear Jianing,
You shouldn't be trying to use ADIC, period.
I suggest you try a Jacobian-free method for now (don't set a function
for determining the SNES solver's Jacobian) and let PETSc handle this
for you.
~~A
On 12/10/06, Jianing Shi <js2615 at columbia.edu> wrote:
> Hi Aron,
> I have gone through the spatial kernel part, which was indeed a
> dense matrix on the local communicator.  Here for the ADIC, I try
> to create the Jacobian for the SNES solver.  Though Matt told me
> that ADIC is an advanced functional in the developers' version.
> Jianing
> Quoting Aron Ahmadia <aja2111 at columbia.edu>:
> > Hi Jianing,
> > You are not using ADIC, this isn't the type of matrix you want to
> > create.  You want a dense matrix on the local communicator, not a
> > DAAD
> > matrix.
> > ~Aron
> > On 12/9/06, Jianing Shi <js2615 at columbia.edu> wrote:
> > > I just added PETSC_HAVE_ADIC, and seems that the compiler does
> > not
> > > complain any more.
> > >   #if defined(PETSC_HAVE_ADIC)
> > >   if (adicmf_jacobian)
> > >     ierr =
> DASetLocalAdicMFFunction(user.da,admf_FormFunctionLocal);CHKERRQ(ierr);
> > >     ierr = MatRegisterDAAD();CHKERRQ(ierr);
> > >     ierr = MatCreateDAAD(user.da,&A);CHKERRQ(ierr);
> > >     ierr = MatDAADSetSNES(A,snes);CHKERRQ(ierr);
> > >     ierr = MatDAADSetCtx(A,&user);CHKERRQ(ierr);
> > >   #endif
> > > Though what is the trick if I really want to use ADIC?
> > > Jianing
> > > Quoting Matthew Knepley <knepley at gmail.com>:
> > > > Are you really using ADIC?
> > > >   Matt
> > > > > I have a question about creating the jacobian here.
> > > > > Here is the code I use to create it.
> > > > >   ierr = DAGetMatrix(user.da,MATAIJ,&J);CHKERRQ(ierr);
> > > > >   A = J;
> > > > >   ierr =
> > > > > I included the head files
> > > > > petscsnes.h    petscda.h
> > > > > When I compile it, I got the following linking error:
> > > > > ld: Undefined symbols:
> > > > > _MatCreateDAAD
> > > > > _MatDAADSetCtx
> > > > > _MatDAADSetSNES
> > > > > _MatRegisterDAAD
> > > > > make: [paraImplicitV1] Error 1 (ignored)
> > > > > Not sure what went wrong.
> > > > > Jianing
> > > > "Failure has a thousand explanations. Success doesn't need
> > one"
> > > > -- Sir
> > > > Alec Guiness
