Configuration crash - can't start new thread
Ben Tay zonexo at gmail.com
Thu Dec 7 04:42:56 CST 2006
It's Redhat. The administrator told me their python ver is 2.2.3. Is that
the reason? However, I've already downloaded and installed the new version.
but the same problem exist. I wonder if it is because petsc is still using
the old version....
On 12/6/06, Satish Balay <balay at mcs.anl.gov> wrote:
> This is wierd. I don't think we've seen this error before. What kind
> of linux is this running? I'm guessing there is a problem on the
> system-software side.. [with threads]
> Satish
> On Wed, 6 Dec 2006, Ben Tay wrote:
> > Hi,
> > sorry, it still can't work. Installation of Python is ok though.
> > the error msg is the same though:
> >             Configuring PETSc to compile on your
> > system
> >          CONFIGURATION CRASH  (Please send configure.log to
> > petsc-maint at mcs.anl.gov)
> >  File "config/configure.py", line 172, in petsc_configure
> >    framework = config.framework.Framework(sys.argv
> [1:]+['--configModules=
> > PETSc.Configure','--optionsModule=PETSc.compilerOptions'], loadArgDB =
> 0)
> >  File
> > "/nas/hpctmp/g0306332/petsc-2.3.2-p7
> /python/BuildSystem/config/framework.py",
> > line 81, in __init__
> >    self.argDB['debugSections'] = ['screen']
> >  File "/nas/hpctmp/g0306332/petsc-2.3.2-p7/python/BuildSystem/RDict.py",
> > line 219, in __setitem__
> >    self.save()
> > line 639, in save
> >    self.saveTimer.start()
> >  File "/nas/home/enduser/g0306332/python-2.4
> /lib/python2.5/threading.py",
> > line 434, in start
> >    _start_new_thread(self.__bootstrap, ())
> > > What linux is this? Just get python sources from http://python.org/
> > > [sugest python-2.4] - and install your own copy - and try with it.
> > > configure python with:
> > > ./configure --prefix=${HOME}/python-2.4
> > > make
> > > make install
> > > And configure PETSc with:
> > > ${HOME}/python-2.4/bin/python config/configure.py
> > > Satish
> > > > Hi,
> > > > I just tried but it's the same error. Any other suggestion?
> > > > thanks!
> > > > On 12/5/06, Matthew Knepley <knepley at gmail.com> wrote:
> > > > > You have a broken Python installation. You can work around this
> using
> > > > > the options --useThreads=0.
> > > > > Thanks,
> > > > >    Matt
> > > > > On 12/5/06, Ben Tay <zonexo at gmail.com> wrote:
> > > > > > Hi,
> > > > > > I tried to compile the library on a linux sys (xeon). It gives
> the
> > > error
> > > > > > msg:
> > > > > >   File "./config/configure.py", line 172, in petsc_configure
> > > > > >     framework =
> > > > > > config.framework.Framework(sys.argv[1:]+['--configModules=
> > > > > > loadArgDB = 0)
> > > > > >   File
> > > > > >     self.save()
> > > > > > line 639, in save
> > > > > >   File "/usr/lib/python2.2/threading.py", line 396, in
> > > > > > start
> > > > > > May I know what's wrong? I also can't find any configure.logfile.
> > > > > > Thank you.
> > > > > > Regards
> > > > > "Failure has a thousand explanations. Success doesn't need one" --
> Sir
> > > > > Alec Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061207/fe4bd419/attachment.htm>
