Re: Re: The support of log double
Tue Dec 5 07:25:48 CST 2006
 Please see the message I posted yesterday.
Date: Mon, 4 Dec 2006 19:51:20 -0600 (CST)        From: Barry Smith <bsmith at mcs.anl.gov>        To: petsc-users <petsc-users at mcs.anl.gov>        Subject: Re: [gb2312] The support of log double        G.D.        You can compile PETSc to use long double with the additional        configure/configure.py options --with-precision=longdouble        --download-c-blas-lapack        It compiles a special version of Blas/Lapack for long double.
On Tue, 5 Dec 2006, Gong Ding wrote:
> I'd like to thank the developers of PETSC.
> I had spent years to develop a semiconductor
> simulation code which based on PETSC. The code is
> carefully checked by valgrind and no memory
> problem should exist.
> In semiconductor, the magnitude of carrier density
> differs much. When the electron density is 10e18,
> the hole density is only 10e2. The sum/sub of two
> variables may have float precision problem and in
> my code, a lot of parameters must be computed with
> density arguments. In most of the situation, my
> code works fine with both gcc/icc except a
> heterojunction BJT example. The code generated by
> icc works but not work with gcc. I guess the float
> point precision in gcc is not enough. (I found a
> ¡°long double¡± description in the configure file of
> icc. Does icc use long double internally?)
> Unfortunately, icc is not free. I have to make gcc
> work. I¡¯d like to try petsc with long double.
> Another requirement, can PETSC functions support
> different ¡°scalar type¡±? For example, by adding a
> postfix letter as BLAS?  The semiconductor code
> needs ¡°real¡± value but I¡¯d like to add optical
> modular which needs ¡°complex¡± value. At present, I
> can only link real lib. As a result, I have to do
> a lot of work on complex->real.
> Yous
> G.D.
> USTC Alumni Email System
