Intel Dual core machines
Thu Aug 24 15:57:33 CDT 2006
mpich2 is also not being developed anymore [on windows]. Either should
work.
[but I'm more familer with mpich1 - if you encounter issues]
Satish
On Thu, 24 Aug 2006, Julian wrote:
> Hi,
> The link to mpich1 says this:
> MPICH.NT is no longer being developed.  Please use  MPICH2. MPICH.NT and
> MPICH2 can co-exist on the same machine so it is not necessary to uninstall
> MPICH to install MPICH2. But applications must be re-compiled with the
> MPICH2 header files and libraries.
> So, is it ok if I use mpich2?
> Thanks,
> Julian.
> > -----Original Message-----
> > From: owner-petsc-users at mcs.anl.gov
> > [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
> > Sent: Thursday, August 24, 2006 10:54 AM
> > To: petsc-users at mcs.anl.gov
> > Subject: Re: Intel Dual core machines
> > If you plan to use windows recommend mpich1 as this is what
> > PETSc is usually tested with [as far as installation is concerned].
> > http://www-unix.mcs.anl.gov/mpi/mpich1/mpich-nt/
> > Configure will automatically look for it - and use it.
> > The scalability depends upon the OS, MPI impl and
> > MemoryBandwidh numbers for this hardware. Don't know enough
> > about the OS & MPI part - but the MemoryBandwidh part is easy
> > to check based on the hardware you have. [The new core duo
> > chips appear to have high memory bandwidth numbers - so I
> > think it should scale well]
> > But you should be concerned about this only for performance measurents
> > - but not during development. [You can install MPI on a
> > single cpu machine and use PETSc on it - for development]
> > Satish
> > > Hello,
> > > So far, I have been using PETSc on a single processor
> > windows machine.
> > > Now, I am planning on using it on a Intel Dual core
> > machine. Before I
> > > start running the installation scripts, I wanted to confirm
> > if I can
> > > use both the processors on this new machine just like how you would
> > > use multiple processors on a supercomputer.
> > > If yes, is there anything special that I need to do when
> > installing PETSc?
> > > I'm guessing I would have to install some MPI software...
> > Which one do
> > > you recommend for windows machines (I saw more than one windows MPI
> > > software on the PETSc website) ?
> > > Thanks,
> > > Julian.
