profiling PETSc code
Matt Funk mafunk at nmsu.edu
Wed Aug 2 16:32:20 CDT 2006
Hi Matt,
thanks for all the help so far. The -info option is really very helpful. So i
think i straightened the actual errors out. However, now i am back to the
original question i had. That is why it takes so much longer on 4 procs than
on 1 proc.
I profiled the KSPSolve(...) as stage 2:
For 1 proc i have:
--- Event Stage 2: Stage 2 of ChomboPetscInterface
VecDot              4000 1.0 4.9158e-02 1.0 4.74e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0 18  0  0  0   2 18  0  0  0   474
VecNorm             8000 1.0 2.1798e-01 1.0 2.14e+08 1.0 0.0e+00 0.0e+00
4.0e+03  1 36  0  0 28   7 36  0  0 33   214
VecAYPX             4000 1.0 1.3449e-01 1.0 1.73e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0 18  0  0  0   5 18  0  0  0   173
MatMult             4000 1.0 3.6004e-01 1.0 3.24e+07 1.0 0.0e+00 0.0e+00
0.0e+00  1  9  0  0  0  12  9  0  0  0    32
MatSolve            8000 1.0 1.0620e+00 1.0 2.19e+07 1.0 0.0e+00 0.0e+00
0.0e+00  3 18  0  0  0  36 18  0  0  0    22
KSPSolve            4000 1.0 2.8338e+00 1.0 4.52e+07 1.0 0.0e+00 0.0e+00
1.2e+04  7100  0  0 84  97100  0  0100    45
PCApply             8000 1.0 1.1133e+00 1.0 2.09e+07 1.0 0.0e+00 0.0e+00
0.0e+00  3 18  0  0  0  38 18  0  0  0    21
for 4 procs i have :
VecDot              4000 1.0 3.5884e+01133.7 2.17e+07133.7 0.0e+00 0.0e+00
4.0e+03  8 18  0  0  5   9 18  0  0 14     1
VecNorm             8000 1.0 3.4986e-01 1.3 4.43e+07 1.3 0.0e+00 0.0e+00
8.0e+03  0 36  0  0 10   0 36  0  0 29   133
VecSet              8000 1.0 3.5024e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAYPX             4000 1.0 5.6790e-02 1.3 1.28e+08 1.3 0.0e+00 0.0e+00
0.0e+00  0 18  0  0  0   0 18  0  0  0   410
VecScatterBegin     4000 1.0 6.0042e+01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 38  0  0  0  0  45  0  0  0  0     0
VecScatterEnd       4000 1.0 5.9364e+01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 37  0  0  0  0  44  0  0  0  0     0
MatMult             4000 1.0 1.1959e+02 1.4 3.46e+04 1.4 0.0e+00 0.0e+00
0.0e+00 75  9  0  0  0  89  9  0  0  0     0
MatSolve            8000 1.0 2.8150e-01 1.0 2.16e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0 18  0  0  0   0 18  0  0  0    83
MatLUFactorNum         1 1.0 1.3685e-04 1.1 5.64e+06 1.1 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0    21
MatILUFactorSym        1 1.0 2.3389e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 9.6083e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSetup               1 1.0 2.1458e-06 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve            4000 1.0 1.2200e+02 1.0 2.63e+05 1.0 0.0e+00 0.0e+00
2.8e+04 84100  0  0 34 100100  0  0100     1
PCSetUp                1 1.0 5.0187e-04 1.2 1.68e+06 1.2 0.0e+00 0.0e+00
4.0e+00  0  0  0  0  0   0  0  0  0  0     6
PCSetUpOnBlocks     4000 1.0 1.2104e-02 2.2 1.34e+05 2.2 0.0e+00 0.0e+00
4.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply             8000 1.0 8.4254e-01 1.2 8.27e+06 1.2 0.0e+00 0.0e+00
8.0e+03  1 18  0  0 10   1 18  0  0 29    28
Now if i understand it right, all these calls summarize all calls between the
pop and push commands. That would mean that the majority of the time is spend
in the MatMult and in within that the VecScatterBegin and VecScatterEnd
commands (if i understand it right).
My problem size is really small. So i was wondering if the problem lies in
that (namely that the major time is simply spend communicating between
processors, or whether there is still something wrong with how i wrote the
code?)
thanks
mat
On Tuesday 01 August 2006 18:28, Matthew Knepley wrote:
> On 8/1/06, Matt Funk <mafunk at nmsu.edu> wrote:
> > Actually the errors occur on my calls to a PETSc functions after calling
> > PETSCInitialize.
> Yes, it is the error I pointed out in the last message.
>    Matt
> > mat
