回复: Re: some problems in using PETSC with FFTW3 package
Hong Zhang hzhang at mcs.anl.gov
Wed Aug 2 11:11:53 CDT 2006
You can retrieve real and imaginary part of a petsc scalar from
PetscRealPart()/PetscImaginaryPart()
See an example at
~petsc/src/ksp/ksp/examples/tutorials/ex11.c
Hong
On Wed, 2 Aug 2006, jiaxun hou wrote:
> Hong Zhang,
>   Thanks for your respones.
>     In FFTW3, complex type is set by double[2], and it is very easy to handle.
>   But in Petsc, I don't konw exactly how the complex type be set. And when I want to do the fast fourier transform on a Petsc's complex vector by using FFTW3, I get the trouble of the translation between Petsc and FFTW3.
>   Regards,
>   Mason
> Hong Zhang <hzhang at mcs.anl.gov> дµÀ£º
> Manson,
> We don't have support for FFTW3 yet(we are currently developing
> an interface between petsc and FFTW3). How do you use FFTW3 in PETSC?
> To build petsc with complex, you need configure petsc with
> '--with-scalar-type=complex'
> Hong
> > Hi all,
> > I am trying to using the package FFTW3 in PETSC.
> > How can I change type from PetscScalar to complex or double[2]?
> > The documentation seems a bit sketchy.
> > Regards
> > Mason
> > ÇÀ×¢ÑÅ»¢Ãâ·ÑÓÊÏä-3.5GÈÝÁ¿£¬20M¸½¼þ£¡
