profiling PETSc code
Matt Funk mafunk at nmsu.edu
Tue Aug 1 19:07:28 CDT 2006
Actually the errors occur on my calls to a PETSc functions after calling
PETSCInitialize.
mat
On Tuesday 01 August 2006 17:49, Matt Funk wrote:
> Hi,
> i don't think it is the mallocs since it says things like:
> [0] MatAssemblyEnd_SeqAIJMatrix size: 2912 X 2912; storage space: 0
> unneeded,2912 used
> [0] MatAssemblyEnd_SeqAIJNumber of mallocs during MatSetValues() is 0
> However, i do get errors. They look like:
> [0]PETSC ERROR: StageLogRegister() line 95 in src/sys/plog/stageLog.c
> [0]PETSC ERROR: Invalid pointer!
> [0]PETSC ERROR: Null Pointer: Parameter # 3!
> [0]PETSC ERROR: PetscLogStageRegister() line 375 in src/sys/plog/plog.c
> which happens during the call PETSCInitialize(...);
> After that i get an error like:
> [0] PetscCommDuplicateDuplicating a communicator 91 164 max tags =
> 1073741823 [0] PetscCommDuplicateUsing internal PETSc communicator 91 164
> [0]PETSC ERROR: MatGetVecs() line 6283 in src/mat/interface/matrix.c
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 1!
> [0]PETSC ERROR: KSPGetVecs() line 555 in src/ksp/ksp/interface/iterativ.c
> [0]PETSC ERROR: KSPDefaultGetWork() line 597 in
> [0]PETSC ERROR: KSPSetUp_CG() line 75 in src/ksp/ksp/impls/cg/cg.c
> [0]PETSC ERROR: KSPSetUp() line 198 in src/ksp/ksp/interface/itfunc.c
> so i suppose that is a problem. I am just not sure what it means.
> any ideas?
> mat
> On Tuesday 01 August 2006 16:36, Matthew Knepley wrote:
> > On 8/1/06, Matt Funk <mafunk at nmsu.edu> wrote:
> > > Hi,
> > > well, now i do get  summary:
> > >      #                          WARNING!!!                    #
> > >       #   This code was run without the PreLoadBegin()         #
> > >       #   macros. To get timing results we always recommend    #
> > >       #   preloading. otherwise timing numbers may be          #
> > >       #   meaningless.                                         #
> > > Event                Count      Time (sec)     Flops/sec
> > > --- Global ---  --- Stage ---   Total
> > >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
> > > len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > > --- Event Stage 0: Main Stage
> > > VecNorm              200 1.0 5.6217e-03 1.0 2.07e+08 1.0 0.0e+00
> > > 0.0e+00 1.0e+02  0 36  0  0  7   0 36  0  0 31   207
> > > VecCopy              200 1.0 4.2303e-03 1.0 0.00e+00 0.0 0.0e+00
> > > 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > VecSet                 1 1.0 8.1062e-06 1.0 0.00e+00 0.0 0.0e+00
> > > VecAYPX              100 1.0 3.2036e-03 1.0 1.82e+08 1.0 0.0e+00
> > > 0.0e+00 0.0e+00  0 18  0  0  0   0 18  0  0  0   182
> > > MatMult              100 1.0 8.3530e-03 1.0 3.49e+07 1.0 0.0e+00
> > > 0.0e+00 0.0e+00  1  9  0  0  0   1  9  0  0  0    35
> > > MatSolve             200 1.0 2.5591e-02 1.0 2.28e+07 1.0 0.0e+00
> > > 0.0e+00 0.0e+00  2 18  0  0  0   2 18  0  0  0    23
> > > MatSolveTranspos     100 1.0 2.1357e-02 1.0 1.36e+07 1.0 0.0e+00
> > > 0.0e+00 0.0e+00  2  9  0  0  0   2  9  0  0  0    14
> > > MatLUFactorNum       100 1.0 4.6215e-02 1.0 6.30e+06 1.0 0.0e+00
> > > 0.0e+00 0.0e+00  3  9  0  0  0   3  9  0  0  0     6
> > > MatILUFactorSym        1 1.0 4.4894e-04 1.0 0.00e+00 0.0 0.0e+00
> > > 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  1     0
> > > MatAssemblyBegin       1 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00
> > > MatAssemblyEnd       100 1.0 1.1220e-02 1.0 0.00e+00 0.0 0.0e+00
> > > 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> > > MatGetOrdering         1 1.0 2.5296e-04 1.0 0.00e+00 0.0 0.0e+00
> > > KSPSetup             100 1.0 5.3692e-04 1.0 0.00e+00 0.0 0.0e+00
> > > 0.0e+00 1.4e+01  0  0  0  0  1   0  0  0  0  4     0
> > > KSPSolve             100 1.0 9.0056e-02 1.0 3.23e+07 1.0 0.0e+00
> > > 0.0e+00 3.0e+02  7 91  0  0 21   7 91  0  0 93    32
> > > PCSetUp              100 1.0 4.9087e-02 1.0 5.93e+06 1.0 0.0e+00
> > > 0.0e+00 4.0e+00  4  9  0  0  0   4  9  0  0  1     6
> > > PCApply              300 1.0 4.9106e-02 1.0 1.78e+07 1.0 0.0e+00
> > > 0.0e+00 0.0e+00  4 27  0  0  0   4 27  0  0  0    18
> > > Memory usage is given in bytes:
> > > Object Type          Creations   Destructions   Memory  Descendants'
> > > Mem.
> > >            Index Set     3              3      35976     0
> > >                  Vec   109            109    2458360     0
> > >               Matrix     2              2      23304     0
> > >        Krylov Solver     1              1          0     0
> > >       Preconditioner     1              1        168     0
> > >== =============================================== Average time to get
> > > PetscTime(): 9.53674e-08
> > > Compiled without FORTRAN kernels
> > > Compiled with full precision matrices (default)
> > > am i using the push and pop calls in an manner they are not intended to
> > > be used?
> > Not exactly. You need to register a stage first before pushing it.
> > http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/m
> >an ualpages/Profiling/PetscLogStageRegister.html
> > > plus, how can i see what's going on with respect to why it takes so
> > > much longer to solve the system in parallel than in serial without
> > > being able to specify the stages (i.e single out the KSPSolve call)?
> > There are 100 calls to KSPSolve() which collectively take .1s. Your
> > problem is most
> > likely in matrix setup. I would bet that you have not preallocated the
> > space correctly.
> > Therefore, a malloc() is called every time you insert a value. You can
> > check the number of mallocs using -info.
> >    Matt
> > > mat
> > > On Tuesday 01 August 2006 15:57, Matthew Knepley wrote:
> > > > ke out your stage push/pop for the moment, and the log_summary
> > > > call. Just run with -log_summary and send the output as a test.
> > > > Thanks,
> > > > Matt
