How to loop Petsc in Fortran?
Mon Apr 24 13:02:16 CDT 2006
    Question 2) You should also use http://valgrind.org/ to determine
where the memory corruption is taking place.
    Barry
On Mon, 24 Apr 2006, Matthew Knepley wrote:
> On 4/24/06, Letian Wang <letian.wang at ghiocel-tech.com> wrote:
>>  Dear All:
>> Question 1):
>> For an optimization task, I need to loop Petsc (I'm using Petsc-2.3.0).
>> But I had problems to reinitialize Petsc after finalize, here is a simple
>> FORTRAN program to explain my problem:
> It is not possible to call MPI_Init() after an MPI_Finalize(). Therefore you
> should only call PetscInitialize/Finalize() once.
>> Question 2):
>> Follow up my previous question, I also tried to Initiallize and Finalize
>> Petsc only once and perform the do-loop between Petscinitialize and
>> PetscFinalize. I used KSP CR solver with Prometheus PCs to solver large
>> linear equations. After several loops, the program was interrupted by
>> segmentation violation error. I suppose there was a memory leak somewhere.
>> The error message is like this: Any suggestion for this? Thanks
> This is a memory corruption problem. Use the debugger (-start_in_debugger)
> to get a stack trace so at
> least we know where  the SEGV is occurring. Then we can try to fix it.
>   Thanks,
>      Matt
>> *********Doing job -- nosort0001
>> Task No.    1    Total CPU=       52.3
>>  *********Doing job -- nosort0002
>> Task No.    2    Total CPU=       52.1
>>  *********Doing job -- nosort0003
>> Petsc Release Version 2.3.0, Patch 44, April, 26, 2005
>> See docs/changes/index.html for recent updates.
>> See docs/faq.html for hints about trouble shooting.
>> See docs/index.html for manual pages.
>> ../feap on a linux-gnu named GPTnode3.cl.ghiocel-tech.com by ltwang Mon
>> Apr 24 15:25:04 2006
>> Libraries linked from /home/ltwang/Library/petsc-2.3.0/lib/linux-gnu
>> Configure run at Tue Mar 14 11:19:49 2006
>> Configure options --with-mpi-dir=/usr --with-debugging=0
>> --download-spooles=1 --download-f-blas-lapack=1 --download-parmetis=1
>> --download-prometheus=1 --with-shared=0
>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
>> run
>> [1]PETSC ERROR: to get more information on the crash.
>> [1]PETSC ERROR: User provided function() line 0 in unknown directory
>> unknown file
>> [1]PETSC ERROR: Signal received!
>> [1]PETSC ERROR:  !
>> [cli_1]: aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
>> [cli_0]: aborting job:
>> Fatal error in MPI_Allgather: Other MPI error, error stack:
>> MPI_Allgather(949)........................: MPI_Allgather(sbuf=0xbffeea14,
>> scount=1, MPI_INT, rbuf=0x8bf0a0c, rcount=1, MPI_INT, comm=0x84000000)
>> failed
>> MPIR_Allgather(180).......................:
>> MPIC_Sendrecv(161)........................:
>> MPIC_Wait(321)............................:
>> MPIDI_CH3_Progress_wait(199)..............: an error occurred while
>> handling an event returned by MPIDU_Sock_Wait()
>> MPIDI_CH3I_Progress_handle_sock_event(422):
>> MPIDU_Socki_handle_read(649)..............: connection failure
>> (set=0,sock=2,errno=104:(strerror() not found))
>> rank 1 in job 477  GPTMaster_53830   caused collective abort of all ranks
>>   exit status of rank 1: return code 59
>> Letian
> "Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
> Guiness
