[petsc-dev] DMPlex overlap redistribution
Adrian Croucher a.croucher at auckland.ac.nz
Mon Mar 4 16:46:07 CST 2024
hi Matt,
On 5/03/24 1:40 am, Matthew Knepley wrote:
> Let's start with the distribution. I think the problem may be here.
> Even with dual porosity cells, I don't think we should have cells in
> the pointSF, just the internal face between cells. Do you agree?
You mean the re-distribution? If you are removing the overlap cells and
then recreating them after redistribution, then I agree, it should be
just faces in the pointSF.
After I've done the initial distribution (with overlap 1), then added
the dual porosity cells, faces etc., I create a new pointSF for the
resulting DMPlex:
https://urldefense.us/v3/__https://github.com/waiwera/waiwera/blob/8bd5e1df1b3eaa728c689d2ec4d8ed35a7ca64f6/src/mesh.F90*L3412__;Iw!!G_uCfscf7eWS!b5nsxRn6Fs2vSvKgF7HaqlN5nQ3ywLAgC1i_djUVTvPYTHRiuQ1yy4mSMNTshFhfhgzBaRDRm7gKT3voRf5jCMqS3DNJK1A$
Mostly that is just updating the original pointSF because the original
DMPlex points have been shifted to make space for the new cells, faces etc.
But if there is something not quite right in there, perhaps that could
cause trouble during the subsequent redistribution?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
Waipapa Taumata Rau / University of Auckland, New Zealand
email:a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240305/cabfe359/attachment.html>
