[petsc-dev] DMPlex overlap redistribution (was: Build error with zlib)
Adrian Croucher a.croucher at auckland.ac.nz
Thu Feb 29 20:41:21 CST 2024
hi Matt,
On 20/01/24 6:03 am, Matthew Knepley wrote:
> I put in a test for redistribution with overlap, Plex test ex12, test
> 7. You can run it using
>   make -f ./gmakefile test search="dm_impls_plex_tests-ex12_7"
> and see the output in src/dm/impls/plex/tests/output/ex12_7.out. The
> second DMPlexDistribute() call
> is made on a mesh with overlap.
> If this is not a solution, can we make a small test that goes in ex12
> that shows what is wrong?
I just got around to testing this with PETSc 3.20.5.
I am still getting problems with redistribution of MINC (dual porosity)
meshes. The function DMPlexCheckPointSF() is now raising errors like this:
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Point SF contains 25 which is a cell
Looking in the PETSc code it appears some extra checks were added about
a year ago (commit 7726db96) including the bit commented "Check there
are no cells in interface", which is what is raising the error.
My understanding of the point SF is a bit rusty now but I would have
thought that for finite volume meshes with overlap 1 (which is what I
have), there should be cells in the interface?
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
Waipapa Taumata Rau / University of Auckland, New Zealand
email:a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240301/fedaa472/attachment.html>
