[petsc-dev] DMPlex redistribution
Thu Nov 30 14:00:18 CST 2023
On Tue, Mar 28, 2023 at 6:12 PM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> > Yes, I think so. The partitioning groups cells, and does not expect cells
> > in the overlap. We could generalize that, which is probably
> > the right thing to do when redistributing meshes with overlap. I will
> look
> > at why it is complaining. Maybe I can just put a guard instead
> > of an error in there.
> Yes, and it might be useful to be able to disable that check for cells
> in the overlap, for cases like this.
Okay, I lost this in my Inbox. Is redistribution of overlapping meshes
still broken? If so, we should make a test so that I can fix it.
  Thanks!
    Matt
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20231130/27bfc8c8/attachment.html>
