[petsc-dev] PetscHMapI passing
Brandon Denton bldenton at buffalo.edu
Tue Nov 28 16:22:58 CST 2023
Good Afternoon,
Ok. I think I've developed a solution that meets everyone's interest. Please review the below and let me know if you have any questions or comments.
Quick background. The objective of this function is to provide user friendly access to geometric data associated with a DMPlex with a geometry CAD model attached. This function will replace the originally conceived PetscObjectQuery() method.
Proposed Function Signature:
DMPlexGetGeomCntrlPntAndWeightData(DM dm, PetscHMapI *cpHashTable, PetscInt *cpCoordDataLength, PetscScalar **cpCoordData, PetscInt *maxNumEquiv, Mat *cpEquiv, PetscHMapI *wHashTable, PetscInt *wDataLength, PetscScalar **wData)
The only input it the DM. All others are outputs.
Proposed Call
   PetscScalar    *cpCoordData, *wData;
    PetscInt              cpCoordDataLength, wDataLength, maxNumEquiv;
    PetscHMapI     cpHashTable, wHashTable;
    Mat                       cpEquiv;
PetscCall(DMPlexGetGeomCntrlPntAndWeightData(dmNozzle, &cpHashTable, &cpCoordDataLength, &cpCoordData, &maxNumEquiv, &cpEquiv, &wHashTable, &wDataLength, &wData));
Proposed Function Added to plexegads.c
  PetscFunctionBeginHot;
#ifdef PETSC_HAVE_EGADS
  PetscContainer  modelObj, cpHashTableObj, wHashTableObj, cpCoordDataObj, wDataObj, cpCoordDataLengthObj, wDataLengthObj, cpEquivObj, maxNumRelateObj;
  PetscInt       *cpCoordDataLengthPtr, *wDataLengthPtr, *maxNumEquivPtr;
  PetscHMapI      cpHashTableTemp, wHashTableTemp;
  PetscScalar    *cpCoordDataTemp, *wDataTemp;
  Mat             cpEquivTemp;
  /* Determine which type of EGADS model is attached to the DM */
  PetscCall(PetscObjectQuery((PetscObject) dm, "EGADS Model", (PetscObject *) &modelObj));
  if (!modelObj) {
    PetscCall(PetscObjectQuery((PetscObject) dm, "EGADSlite Model", (PetscObject *) &modelObj));
  if (!modelObj) {PetscFunctionReturn(PETSC_SUCCESS);}
  // Look to see if DM has Container for Geometry Control Point Data
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Hash Table", (PetscObject *)&cpHashTableObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Coordinates", (PetscObject *)&cpCoordDataObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Coordinate Data Length", (PetscObject *)&cpCoordDataLengthObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Weights Hash Table", (PetscObject *)&wHashTableObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Weight Data", (PetscObject *)&wDataObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Weight Data Length", (PetscObject *)&wDataLengthObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Control Point Equivalancy Matrix", (PetscObject *)&cpEquivObj));
  PetscCall(PetscObjectQuery((PetscObject)dm, "Maximum Number Control Point Equivalency", (PetscObject *)&maxNumRelateObj));
  // Get attached EGADS model Control Point and Weights Hash Tables and Data Arrays (pointer)
  PetscCall(PetscContainerGetPointer(cpHashTableObj, (void **)&cpHashTableTemp));
  PetscCall(PetscContainerGetPointer(cpCoordDataObj, (void **)&cpCoordDataTemp));
  PetscCall(PetscContainerGetPointer(cpCoordDataLengthObj, (void **)&cpCoordDataLengthPtr));
  PetscCall(PetscContainerGetPointer(wHashTableObj, (void **)&wHashTableTemp));
  PetscCall(PetscContainerGetPointer(wDataObj, (void **)&wDataTemp));
  PetscCall(PetscContainerGetPointer(wDataLengthObj, (void **)&wDataLengthPtr));
  PetscCall(PetscContainerGetPointer(cpEquivObj, (void **)&cpEquivTemp));
  PetscCall(PetscContainerGetPointer(maxNumRelateObj, (void **)&maxNumEquivPtr));
  *cpCoordDataLength = *cpCoordDataLengthPtr;
  *wDataLength = *wDataLengthPtr;
  *maxNumEquiv = *maxNumEquivPtr;
  *cpEquiv = cpEquivTemp;
  *cpHashTable = cpHashTableTemp;
  *wHashTable = wHashTableTemp;
  *cpCoordData = cpCoordDataTemp;
  *wData = wDataTemp;
  #endif
Sent: Tuesday, November 28, 2023 1:26 PM
To: Barry Smith <bsmith at petsc.dev>
Cc: Brandon Denton <bldenton at buffalo.edu>; petsc-dev at mcs.anl.gov <petsc-dev at mcs.anl.gov>
Subject: Re: [petsc-dev] PetscHMapI passing
On Mon, Nov 27, 2023 at 1:00 PM Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  What errors do you get?
I am trying to develop a function where the user can specify an empty PetscHMapI variable and the function will retrieve the information attached to the DMPlex. However, when I try something like ...
PETSC_EXTERN PetscErrorCode DMPlexGetGeomInfo(DM dm, PetscHMapI hashTable)
  I don't understand the design of specifying and empty one. Why not have
PETSC_EXTERN PetscErrorCode DMPlexGetGeomInfo(DM dm, PetscHMapI *hashTable)
and return the one you have inside your container?
This sounds like the right design. Does that work?
    Matt
On Nov 27, 2023, at 9:11 AM, Brandon Denton via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Good Morning,
I am trying to develop a function in PETSc that allows for the retrieval of a PetscHMapI contained in a PetscContainer attached to a DMPlex. The creation of this Hash Table and its attachment to the DMPlex is automated as part of the CAD/Discretization integration I've been developing. Currently, the only way to get this Hash Table is through the PetscObjectQuery() functionality. In an effort to make it easier for users to access and use this information, I am trying to develop a function where the user can specify an empty PetscHMapI variable and the function will retrieve the information attached to the DMPlex. However, when I try something like ...
I get a ton of compilation errors associated with the PetscHMapI designation. Is there a way around this?
Thank you.
Brandon
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20231128/03b896ec/attachment-0001.html>
