[petsc-dev] Issue with -log_view
Jose E. Roman jroman at dsic.upv.es
Tue May 9 08:46:24 CDT 2023
https://gitlab.com/petsc/petsc/-/merge_requests/6440
> El 9 may 2023, a las 15:31, Matthew Knepley <knepley at gmail.com> escribió:
> On Tue, May 9, 2023 at 9:04 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> I found the bug: the event MAT_MultHermitianTranspose is used but not registered.
> I will create a MR.
> Great!
>   Thanks,
>     Matt
> Thanks Matt.
> > El 9 may 2023, a las 14:50, Matthew Knepley <knepley at gmail.com> escribió:
> > On Tue, May 9, 2023 at 8:41 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > But MatCreateShell() calls MatInitializePackage() (via MatCreate()) and also the main program creates a regular Mat. The events should have been registered by the time the shell matrix operations are invoked.
> > The reason I say this is that PetscBarrier is the _first_ event, so if an event is called without initializing, it
> > will show up as PetscBarrier. Maybe break in MatMultTranspose, to see who is calling it first?
> >   Thanks,
> >     Matt
> > > El 9 may 2023, a las 14:13, Matthew Knepley <knepley at gmail.com> escribió:
> > > On Tue, May 9, 2023 at 7:17 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > > Hi.
> > > We are seeing a strange thing in the -log_view output with one of the SLEPc solvers. It is probably an issue with SLEPc, but we don't know how to debug it.
> > > It can be reproduced for instance with
> > >  $ ./ex45 -m 15 -n 20 -p 21 -svd_nsv 4 -svd_ncv 9 -log_view
> > > The log_view events are listed at the end of this email. The first one (PetscBarrier) is wrong, because PetscBarrier is never called, if I place a breakpoint in PetscBarrier() it will never be hit. Also, in that event it reports some nonzero Mflop/s, which suggests that it corresponds to another event (not PetscBarrier). Furthermore, the count of the PetscBarrier event always matches the count of MatMultTranspose, so there must be a connection.
> > > Does anyone have suggestions how to address this?
> > > Hi Jose,
> > > Here is my guess. PETSc sets all of the event ids (using Register) when the dynamic libraries get loaded. If they are not loaded,
> > > then the library initialization function is called when some function from that library is used. My guess is that we put this init check
> > > in MatCreate(), but that is not called when you create your shell matrix and thus the events are not initialized correctly for you until
> > > later. Can you check?
> > >   Thanks,
> > >      Matt
> > > Note: this is with 1 MPI process.
> > > Note: the solver creates a shell matrix with MATOP_MULT_TRANSPOSE.
> > > Thanks.
> > > Jose
> > > PetscBarrier          16 1.0 7.5579e-04 1.0 4.38e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     6
> > > MatMult               82 1.0 6.1590e-01 1.0 9.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 97  0  0  0  81 97  0  0  0     2
> > > MatMultTranspose      16 1.0 7.4625e-04 1.0 4.38e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     6
> > > MatAssemblyBegin       4 1.0 5.2452e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > MatAssemblyEnd         4 1.0 2.8920e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > MatTranspose           2 1.0 1.6265e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > SVDSetUp               1 1.0 1.8686e-02 1.0 2.72e+02 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
> > > SVDSolve               1 1.0 5.5965e-01 1.0 7.95e+05 1.0 0.0e+00 0.0e+00 0.0e+00 74 83  0  0  0  74 83  0  0  0     1
> > > EPSSetUp               1 1.0 9.5146e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> > > EPSSolve               1 1.0 5.4082e-01 1.0 7.94e+05 1.0 0.0e+00 0.0e+00 0.0e+00 71 83  0  0  0  71 83  0  0  0     1
> > > STSetUp                1 1.0 4.8406e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> > > STComputeOperatr       1 1.0 1.2653e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > STApply               24 1.0 6.1569e-01 1.0 8.84e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
> > > STMatSolve            24 1.0 6.1556e-01 1.0 8.80e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
> > > KSPSetUp               1 1.0 2.8465e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > KSPSolve              24 1.0 6.1551e-01 1.0 8.80e+05 1.0 0.0e+00 0.0e+00 0.0e+00 81 92  0  0  0  81 92  0  0  0     1
> > > KSPGMRESOrthog       480 1.0 4.3219e-01 1.0 3.98e+05 1.0 0.0e+00 0.0e+00 0.0e+00 57 42  0  0  0  57 42  0  0  0     1
> > > PCSetUp                1 1.0 3.8147e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > PCApply              504 1.0 2.1615e-02 1.0 1.01e+04 1.0 0.0e+00 0.0e+00 0.0e+00  3  1  0  0  0   3  1  0  0  0     0
> > > BVCopy                27 1.0 3.0560e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > BVMultVec             38 1.0 3.7060e-03 1.0 8.88e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0     2
> > > BVMultInPlace          3 1.0 1.0681e-04 1.0 4.32e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    40
> > > BVDotVec              38 1.0 4.5121e-03 1.0 4.38e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0    10
> > > BVOrthogonalizeV      20 1.0 1.3182e-02 1.0 5.33e+04 1.0 0.0e+00 0.0e+00 0.0e+00  2  6  0  0  0   2  6  0  0  0     4
> > > BVScale               24 1.0 4.8089e-04 1.0 4.80e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1
> > > BVNormVec              4 1.0 5.4097e-04 1.0 3.67e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     7
> > > BVNormalize            1 1.0 1.3154e-03 1.0 3.75e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     3
> > > BVSetRandom            1 1.0 9.1791e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > BVMatMultVec          19 1.0 4.6828e-01 1.0 6.99e+05 1.0 0.0e+00 0.0e+00 0.0e+00 62 73  0  0  0  62 73  0  0  0     1
> > > DSSolve                3 1.0 8.8906e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > DSVectors              7 1.0 2.8920e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > DSOther               12 1.0 3.8576e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > VecDot                 4 1.0 8.7500e-05 1.0 1.56e+02 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     2
> > > VecMDot              488 1.0 6.0463e-04 1.0 1.98e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0 21  0  0  0   0 21  0  0  0   327
> > > VecNorm              520 1.0 1.0412e-02 1.0 2.02e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0     2
> > > VecScale             514 1.0 1.0245e-02 1.0 1.03e+04 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0     1
> > > VecCopy               62 1.0 1.8365e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > VecSet                64 1.0 4.2200e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > VecAXPY               32 1.0 4.8995e-04 1.0 1.44e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     3
> > > VecMAXPY             504 1.0 6.9070e-04 1.0 2.21e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0 23  0  0  0   0 23  0  0  0   320
> > > VecPointwiseMult     504 1.0 3.3593e-04 1.0 1.01e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0    30
> > > VecSetRandom           1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > > VecNormalize         512 1.0 4.1106e-02 1.0 3.01e+04 1.0 0.0e+00 0.0e+00 0.0e+00  5  3  0  0  0   5  3  0  0  0     1
> > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> > -- Norbert Wiener
> -- Norbert Wiener
