[petsc-dev] Inquiry about a change in petsc version 3.19.1
Barry Smith bsmith at petsc.dev
Tue Jun 20 19:35:52 CDT 2023
  I don't think the change was "necessary" for bt; I made the change to have more "robustness" for a sloppily provided maximum step length. That is for people who did not understand their problem's length scales. I was too quick to make the change without more thought. I don't have any underlying mathematical principles to rely on for handling appropriate maximum and minimum lengths, thus it has always been ad hoc.
   Barry
> On Jun 20, 2023, at 3:21 PM, Nabil Abboud <nabil.abboud at ansys.com> wrote:
> Hi Barry,
> I just wanted to follow up on your previous email. Regarding the change that was made to the maxstep for the linesearch in petsc version 3.19.1, was this change necessary for the bt line search to work properly? The reason I am asking is because if so, then if we revert that part of the code back to how it was in petsc version 3.19.0 does it mean that the bt line search won't function properly?
> Thank you.
> Best,
> Nabil
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Sent: Tuesday, June 20, 2023 12:55 PM
> To: Nabil Abboud <nabil.abboud at ansys.com <mailto:nabil.abboud at ansys.com>>
> Cc: petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov> <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
> Subject: Re: [petsc-dev] Inquiry about a change in petsc version 3.19.1
> [External Sender]
>   Looks like a fatally flawed change I should never have made. I have an MR to revert it https://gitlab.com/petsc/petsc/-/merge_requests/6620 Should get into release and main by tommorow.
>   Barry
>> On Jun 19, 2023, at 4:37 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   Sorry about this, we'll take a look and get back to you.
>>> On Jun 19, 2023, at 4:05 PM, Nabil Abboud via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>>> Dear all,
>>> We were trying to update the petsc version we use in our code to the version 3.19.1 when we noticed that some of the unit tests in our code started failing. The reason for the failure seems to be due to a change in the linesearch logic of petsc version 3.19.1. In particular, the implementation of the function SNESLineSearchGetTolerances was modified such that maxstep is now scaled with fnorm as shown in the following link https://gitlab.com/petsc/petsc/-/blob/main/src/snes/linesearch/interface/linesearch.c#L1097
>>> This change seems to be inconsistent with the way maxstep is being used later on to compute a step size using the l2 line search algorithm, for instance, check the following code https://gitlab.com/petsc/petsc/-/blob/main/src/snes/linesearch/impls/l2/linesearchl2.c#L119 where maxstep is compared to lambda_update and where maxstep is scaled by fnorm whereas lambda_update seems to be a scalar of a different order as computed here https://gitlab.com/petsc/petsc/-/blob/main/src/snes/linesearch/impls/l2/linesearchl2.c#L111 .
>>> The way this change is reflected in our code is that we were trying to enforce a range for the step size provided by the l2 line search between 0.1 and 1 and now with the new changes in petsc version 3.19.1 the upper limit seems not to hold anymore and we are seeing step sizes larger than 1.
>>> Thank you in advance for your help.
>>> Best regards,
>>> Nabil
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230620/ab9cc251/attachment.html>
