[petsc-dev] make checkclangformat checkbadSource dependencies
Barry Smith bsmith at petsc.dev
Sun Jun 18 18:51:26 CDT 2023
  Jacobi,
  Thanks for the reminder about using hooks for this purpose. Perhaps git hooks are not understood well enough at the time by the masses (that is, me), or perhaps hooks were presented as THE solution, not as a tool for helping users to get to the solution?  That is, git-hooks as a way to enforce rules on the pushed code versus git hooks used by individuals to make their workflow easier or less bug-prone?
  I found your https://gitlab.com/petsc/petsc/-/merge_requests/4063 but couldn't find any discussion of pre-commits for clang-format in my mail searches.
   I discovered a .git/hooks/pre-commit~ which presumably you sent around (listed at the bottom of this email).  It seems to work as advertised, warns me, and prevents my commit of badly formatted code.
   I modified it to
/bin/bash
current_source=$(git diff --staged --name-only)
badsource=$(make -e GITSRC="${current_source}" checkbadSource 2>&1)
if [ "$badsource" != "" ]
then
    echo "git commit aborted due to violations of basic source code formatting"
    exit 1
fi
clangformatout=$(git clang-format --diff --staged -q)
if [ "$clangformatout" != "" ]
then
    echo "git commit aborted. Use 'git add -u ; git clang-format --staged' to fix source code formatting"
    exit 1
fi
and it seems to suit my needs.
Thanks again for the suggestion
/bin/bash
if git rev-parse --verify HEAD >/dev/null 2>&1
then
against=HEAD
else
# Initial commit: diff against an empty tree object
against=4b825dc642cb6eb9a060e54bf8d69288fbee4904
fi
# Test clang-format
# Redirect output to stderr.
exec 1>&2
then
    echo "Format error!"
    echo "Use git clang-format"
    exit 1
fi
> On Jun 18, 2023, at 4:37 PM, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
>> I want to automatically run make checkclangformat checkbadSource before every git push (because I am an idiot and have too many silly failed CIs due to bad source).
> What you *actually* want are git hooks (https://git-scm.com/book/en/v2/Customizing-Git-Git-Hooks) combined with clang-format-diff (https://clang.llvm.org/docs/ClangFormat.html#script-for-patch-reformatting).
> I floated the idea of adding git hooks ages ago, but it was shot down for some reason.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
>> On Jun 18, 2023, at 16:33, Barry Smith <bsmith at petsc.dev> wrote:
>> I have never understood how to do make rule dependencies when one is not explicitly generating new files from old ones. For example, .o from .c
>> Currently, we use git ls-files and check every single file each time, even though I have not changed all 5,000 source files in PETSc before a push.
>> Is there someone who understands make dependencies when no files are generated who could reduce make checkclangformat and checkbadSource to under a second?
>> Thanks
>> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230618/1ad683a0/attachment-0001.html>
