[petsc-dev] Building libCEED with -fsanitize=address
Tue Jun 13 10:05:38 CDT 2023
For some reason, libCEED seems broken with Address Sanitizer
           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
  Error running make on libceed: Could not execute
"[['/PETSc3/petsc/apple/bin/make',
  '-j13', '-l24.0', 'prefix=/PETSc3/petsc/petsc-pylith/arch-pylith-debug',
'V=1',
  'CC=/PETSc3/petsc/apple/bin/mpicc', 'CFLAGS= -fPIC -Wall -Wwrite-strings
  -Wno-unknown-pragmas -fstack-protector -fno-stack-check -Qunused-arguments
  -fvisibility=hidden -fsanitize=address ',
'CXX=/PETSc3/petsc/apple/bin/mpicxx',
  'CXXFLAGS= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
  -fstack-protector -fno-stack-check -fvisibility=hidden -fsanitize=address
 -std=gnu++17
  -fPIC ', '-B']]":
  make: 'lib' with optional backends: /cpu/self/memcheck/serial
/cpu/self/memcheck/blocked
  /PETSc3/petsc/apple/bin/mpicc -I./include -fPIC -Wall -Wwrite-strings
  .... more output .....
  mcheck/ceed-memcheck-qfunction.o
build/backends/memcheck/ceed-memcheck-qfunctioncontext.o
  build/backends/memcheck/ceed-memcheck-serial.o
  build/backends/memcheck/ceed-memcheck-vector.o
build/backends/ceed-backend-weak.o
  build/gallery/ceed-gallery-weak.o
-lm/PETSc3/petsc/petsc-pylith/arch-pylith-debug/externalpackages/git.libceed/interface/ceed-preconditioning.c:44:9:
  warning: initializing 'char *' with an expression of type 'const char
[1]' discards
  qualifiers [-Wincompatible-pointer-types-discards-qualifier
  .... more error .....
  ceed-operator.o
  _asan.module_ctor in ceed-preconditioning.o
  ld: symbol(s) not found for architecture x86_64
  clang: error: linker command failed with exit code 1 (use -v to see
invocation)
  make: *** [Makefile:517: lib/libceed.dylib] Error 1
Does anyone else see this?
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230613/d6a29acf/attachment.html>
