[petsc-dev] Question about PETSc and pardiso
Thu Jul 13 12:20:25 CDT 2023
On Thu, Jul 13, 2023 at 12:43 PM Cea, Stephen M <stephen.m.cea at intel.com>
wrote:
> Hi,
>             I had a questions about PETSc and pardiso integration.    Can
> you use any of the built into PETSc matrix reordering routines with pardiso
> or just the built in options in pardiso?
Currently, you can only use the built-in reorderings.
However, it would be simple to extend. We already support using a
user-supplied permutation
  -mat_mkl_pardiso_5
but there is no interface for setting the "perm" array in the
Pardiso struct. We could add an interface
to take the IS from MatGetOrdering() and stick it into this array. Note
that Pardiso only supports symmetric
reorderings.
     Matt
> Thanks!
> steve
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230713/6ebd9d8f/attachment.html>
