[petsc-dev] correspondence between include file and library ?
Barry Smith bsmith at petsc.dev
Thu Dec 21 22:47:52 CST 2023
  To make this a bit more complicated, in Fortran when modules need to be used the ksp module will need to be used, not just the mat one. So some possible inconsistencies between the language usage.
  Barry
> On Dec 21, 2023, at 10:28 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Certain Mat implementations (and associated utility user-level functions) need to go in the KSP library because they use KSP even though, from the user point of view, they only have a Mat-level API.
> Where should the information needed in the include files go? For MATLMVM they are mixed up some in petscmat.h and some in petscksp.h
> $ grep MAT include/petscksp.h
> .  `KSP_DIVERGED_INDEFINITE_MAT` - the operator was indefinite for a `KSPType` that requires it be definite
>   KSP_DIVERGED_INDEFINITE_MAT            = -10,
>   MAT_SCHUR_COMPLEMENT_AINV_DIAG,
>   MAT_SCHUR_COMPLEMENT_AINV_LUMP,
>   MAT_SCHUR_COMPLEMENT_AINV_BLOCK_DIAG,
>   MAT_SCHUR_COMPLEMENT_AINV_FULL
>   MAT_LMVM_SYMBROYDEN_SCALE_NONE     = 0,
>   MAT_LMVM_SYMBROYDEN_SCALE_SCALAR   = 1,
>   MAT_LMVM_SYMBROYDEN_SCALE_DIAGONAL = 2,
>   MAT_LMVM_SYMBROYDEN_SCALE_USER     = 3
> ~/Src/petsc (barry/2023-12-21/fix-dmproject/release *>) arch-fix-dmproject
> $ grep MATLMVM include/petscmat.h
> #define MATLMVM                      "lmvm"
> #define MATLMVMDFP                   "lmvmdfp"
> #define MATLMVMBFGS                  "lmvmbfgs"
> #define MATLMVMSR1                   "lmvmsr1"
> #define MATLMVMBROYDEN               "lmvmbroyden"
> #define MATLMVMBADBROYDEN            "lmvmbadbroyden"
> #define MATLMVMSYMBROYDEN            "lmvmsymbroyden"
> #define MATLMVMSYMBADBROYDEN         "lmvmsymbadbroyden"
> #define MATLMVMDIAGBROYDEN           "lmvmdiagbroyden"
> Should they all go in petscksp.h or all in petscmat.h ? Seems bad to have some arbitrarily in each? I vote for petscmat.h since then their docs also go in the Mat docs and users don't need to think "Oh, because MATLMVM uses a KSP in its implementation (why should users need to know or care about this?) I also need include petscksp.h even though MY code does not use KSP at all."
> Thoughts
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20231221/43177ac7/attachment-0001.html>
