[petsc-dev] PETSc optimization
Tue Aug 8 12:24:03 CDT 2023
Well in spack world - the idea is to get flags from spack and use it in petsc build. Its possible that there are issues in this implementation.
Something spack does is - it internally adds in flags (to the compiler - via its compiler wrapper) - that petsc configure doesn't see.
I see 'spack install cflags=-O3' is working - but not spack install cflags='-O3 -g' [something to debug]
[there is also the alternative of adding flags to compiler spec file]
The other issue is mapping cflags from spack to CFLAGS/COPTFLAGS - in some cases petsc build requires some default CLFAGS to work - and overriding them from spack might cause issues. [again this part is not properly handed]..
Satish
On Tue, 8 Aug 2023, Liu Wei   AWE via petsc-dev wrote:
> Hi all
> I am currently building a large software stack using Spack with PETSc 3.19 as part of the dependency library.
> Spotted the following message during the build process
> Using default optimization C flags "-g -O". You might consider manually setting optimal optimization flags for your system with
> COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
> Previously when we install PETSc manually, optimisation flags are enforced via configure script e.g.
> COPTFLAGS="-g -O3 -march=native"
> CXXOPTFLAGS="-g -O3 -march=native"
> (or "-g -O3 -xhost" for intel compiler)
> Whilst spack spec syntax allows compiler parameters via cflags/cxxflags/fflags
> https://github.com/spack/spack/blob/develop/var/spack/repos/builtin/packages/petsc/package.py<https://github.com/spack/spack/blob/develop/var/spack/repos/builtin/packages/petsc/package.py#L400>
> the requirement is not obvious, especially in a long build process.
> The question is should optimisation be amended at spack recipe stage or should PETSc configure enforce some compiler optimisation (if -with-debugging=0 is set) ?
> Regards
> Dr Wei Liu
> High Performance Computing
> To chat with me on Teams click here<https://teams.microsoft.com/l/chat/0/0?users=wei.liu@awe.co.uk>
> T: +44 01189 856209
> M: wei.liu at awe.co.uk<mailto:wei.liu at awe.co.uk>
> AWE Aldermaston,
> Reading, Berkshire, RG7 4PR
> The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited. Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer. While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected. AWE Plc Registered in England and Wales Registration No 02763902 AWE, Aldermaston, Reading, RG7 4PR
