[petsc-dev] So CFLAGS no longer works!!!! Major crisis
Wed Apr 26 17:16:05 CDT 2023
Not sure how can add deprecation message here - so adding this message to 'changes' doc
https://gitlab.com/petsc/petsc/-/merge_requests/6382
Satish
On Wed, 26 Apr 2023, Satish Balay via petsc-dev wrote:
> On Wed, 26 Apr 2023, Barry Smith wrote:
> >   Urg, so user makefiles that worked for 25+ years suddenly don't work and that is ok? No deprecation message as Jed would have liked?
> I think I raised this issue when 'CFLAGS = ' stuff was removed from all makefiles.
> You can view this change as a necessary fix for above cleanup change..
> Don't know if there is gnumake syntax where the reset in PETSC_ARCH/lib/conf/petscvaribales can selectively reset only on env variable - but not prior make variable
> Right now the fix is to move the 'CFLAGS' line after the the 'include' line
> Satish
> >   So it is from
> >     # Avoid picking CFLAGS etc from env - but support 'make CFLAGS=-Werror' etc..
> >     self.addMakeMacro('CFLAGS','')
> >     self.addMakeMacro('CPPFLAGS','')
> >     self.addMakeMacro('CXXFLAGS','')
> >     self.addMakeMacro('CXXPPFLAGS','')
> >     self.addMakeMacro('FFLAGS','')
> >     self.addMakeMacro('FPPFLAGS','')
> >     self.addMakeMacro('CUDAFLAGS','')
> >     self.addMakeMacro('CUDAPPFLAGS','')
> >     self.addMakeMacro('HIPFLAGS','')
> >     self.addMakeMacro('HIPPPFLAGS','')
> >     self.addMakeMacro('SYCLFLAGS','')
> >     self.addMakeMacro('SYCLPPFLAGS','')
> >     self.addMakeMacro('LDFLAGS','')
> > What was "from env" suppose to mean? You mean environmental variables?
> > Is there some other way of not automatically using the environmental variables that doesn't break 25 years of user makefile? Since these things all require GNUmake is there some GNUmake-ish way to hand this without breaking current makefiles?
> > > On Apr 26, 2023, at 5:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Well we wanted to always have  CFLAGS initialized by configure [to ignore stuff from env].
> > > So now - if we are setting in makefile - it has to be set after this default is set - i.e after the line:
> > > include ${PETSC_DIR}/lib/petsc/conf/variables
> > > Or do:
> > > make CFLAGS=garbase ex1
> > > There might be a different bug lurking here..
> > > -PETSC_CCOMPILE_SINGLE   = ${CC} -o $*.o -c ${CC_FLAGS} ${FLAGS} ${CPPFLAGS}
> > > +PETSC_CCOMPILE_SINGLE   = ${CC} -o $*.o -c ${CC_FLAGS} ${CFLAGS} ${CPPFLAGS}
> > > Satish
> > >> $ make ex1
> > >> mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind  -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fvisibility=hidden -g3 -O0  -I/Users/barrysmith/Src/petsc/include -I/Users/barrysmith/Src/petsc/arch-release/include -I/opt/X11/include      ex1.c  -Wl,-rpath,/Users/barrysmith/Src/petsc/arch-release/lib -L/Users/barrysmith/Src/petsc/arch-release/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -Wl,-rpath,/Users/barrysmith/soft/mpich-clang-gfortran-opt/lib -L/Users/barrysmith/soft/mpich-clang-gfortran-opt/lib -Wl,-rpath,/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc/aarch64-apple-darwin22/12 -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc/aarch64-apple-darwin22/12 -Wl,-rpath,/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc -Wl,-rpath,/opt/homebrew/Cellar/gcc/12
 .2
>  .0/lib/g
>  cc/current -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current -lpetsc -llapack -lblas -lX11 -lmpifort -lmpi -lpmpi -lgfortran -lemutls_w -lquadmath -lstdc++ -lquadmath -o ex1
> > >> ~/Src/petsc/src/snes/tutorials (release *=) arch-release
> > >> $ more makefile
> > >> -include ../../../petscdir.mk
> > >> MANSEC           = SNES
> > >> EXAMPLESMATLAB   = ex5m.m ex29view.m
> > >> DIRS             = ex10d network
> > >> CLEANFILES       = ex5f90t
> > >> CFLAGS = garbage
> > >> The new stuff in variables PETSC_COMPILE_SINGLE    = ${PCC} -o $*.o -c ${PCC_FLAGS} ${${CLANGUAGE}FLAGS} ${CCPPFLAGS}  with the recursive use of $ doesn't work? This is on my Mac but Get also has the problem on Polaris
