[petsc-dev] So CFLAGS no longer works!!!! Major crisis
Barry Smith bsmith at petsc.dev
Wed Apr 26 16:46:52 CDT 2023
  Urg, so user makefiles that worked for 25+ years suddenly don't work and that is ok? No deprecation message as Jed would have liked?
  So it is from
    # Avoid picking CFLAGS etc from env - but support 'make CFLAGS=-Werror' etc..
    self.addMakeMacro('CFLAGS','')
    self.addMakeMacro('CPPFLAGS','')
    self.addMakeMacro('CXXFLAGS','')
    self.addMakeMacro('CXXPPFLAGS','')
    self.addMakeMacro('FFLAGS','')
    self.addMakeMacro('FPPFLAGS','')
    self.addMakeMacro('CUDAFLAGS','')
    self.addMakeMacro('CUDAPPFLAGS','')
    self.addMakeMacro('HIPFLAGS','')
    self.addMakeMacro('HIPPPFLAGS','')
    self.addMakeMacro('SYCLFLAGS','')
    self.addMakeMacro('SYCLPPFLAGS','')
    self.addMakeMacro('LDFLAGS','')
What was "from env" suppose to mean? You mean environmental variables?
Is there some other way of not automatically using the environmental variables that doesn't break 25 years of user makefile? Since these things all require GNUmake is there some GNUmake-ish way to hand this without breaking current makefiles?
> On Apr 26, 2023, at 5:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Well we wanted to always have  CFLAGS initialized by configure [to ignore stuff from env].
> So now - if we are setting in makefile - it has to be set after this default is set - i.e after the line:
> include ${PETSC_DIR}/lib/petsc/conf/variables
> Or do:
> make CFLAGS=garbase ex1
> There might be a different bug lurking here..
> -PETSC_CCOMPILE_SINGLE   = ${CC} -o $*.o -c ${CC_FLAGS} ${FLAGS} ${CPPFLAGS}
> +PETSC_CCOMPILE_SINGLE   = ${CC} -o $*.o -c ${CC_FLAGS} ${CFLAGS} ${CPPFLAGS}
> Satish
> On Wed, 26 Apr 2023, Barry Smith wrote:
>> $ make ex1
>> mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind  -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fvisibility=hidden -g3 -O0  -I/Users/barrysmith/Src/petsc/include -I/Users/barrysmith/Src/petsc/arch-release/include -I/opt/X11/include      ex1.c  -Wl,-rpath,/Users/barrysmith/Src/petsc/arch-release/lib -L/Users/barrysmith/Src/petsc/arch-release/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -Wl,-rpath,/Users/barrysmith/soft/mpich-clang-gfortran-opt/lib -L/Users/barrysmith/soft/mpich-clang-gfortran-opt/lib -Wl,-rpath,/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc/aarch64-apple-darwin22/12 -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc/aarch64-apple-darwin22/12 -Wl,-rpath,/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc -Wl,-rpath,/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current -lpetsc -llapack -lblas -lX11 -lmpifort -lmpi -lpmpi -lgfortran -lemutls_w -lquadmath -lstdc++ -lquadmath -o ex1
>> ~/Src/petsc/src/snes/tutorials (release *=) arch-release
>> $ more makefile
>> -include ../../../petscdir.mk
>> MANSEC           = SNES
>> EXAMPLESMATLAB   = ex5m.m ex29view.m
>> DIRS             = ex10d network
>> CLEANFILES       = ex5f90t
>> CFLAGS = garbage
>> The new stuff in variables PETSC_COMPILE_SINGLE    = ${PCC} -o $*.o -c ${PCC_FLAGS} ${${CLANGUAGE}FLAGS} ${CCPPFLAGS}  with the recursive use of $ doesn't work? This is on my Mac but Get also has the problem on Polaris
