[petsc-dev] Regression bug in Merge branch 'knepley/feature-hybrid-mass' into 'main'
Sun Apr 23 19:11:43 CDT 2023
On Fri, Apr 21, 2023 at 4:08 PM Blaise Bourdin <bourdin at mcmaster.ca> wrote:
> There is one remaining problem: in ones.c:753
> J = snes->jacobian;
> PetscCall(DMGetDS(dm, &prob));
> This call fails if a snes was created but the Jacobian function was not
> given (for instance when using -snes_type qn)
> Would it make sense to have DMGetDS to silently return NULL when no DS is
> defined instead of throwing and error?
Yes, I am fine with this change.
    Matt
> Regards,
> Blaise
> On Apr 21, 2023, at 4:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Thanks! I guess none of my examples use DMGetMatrix(). They get the
> Jacobian from the solver, which must just call preallocate.
>   Matt
> On Thu, Apr 20, 2023 at 3:33 PM Blaise Bourdin <bourdin at mcmaster.ca>
> wrote:
>> Actually that was an easy fix… see MR !6352
>> <https://gitlab.com/petsc/petsc/-/merge_requests/6352>
>> On Apr 20, 2023, at 9:18 PM, Blaise Bourdin <bourdin at mcmaster.ca> wrote:
>> Hi,
>> I just noticed that b6b5caf99979f50a7774afdccea5ca5661fc1203 Merge branch
>> 'knepley/feature-hybrid-mass' into ‘main’ seems to have introduced a bug
>> See the attached example (a very simple update of
>> src/dm/impls/plex/tests/ex98.c)
>> When calling DMGetMatrix, I get the following error:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: Need to call DMCreateDS() before calling DMGetDS()
>> [0]PETSC ERROR: WARNING! There are option(s) set that were not used!
>> Could be the program crashed before they were used or a spelling mistake,
>> etc!
>> [0]PETSC ERROR:   Option left: name:-dm_mat_view (no value) source:
>> command line
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision:
>> v3.18.5-1161-gb6b5caf9997  GIT Date: 2023-03-27 14:14:19 +0000
>> [0]PETSC ERROR: ./ex98 on a ventura-gcc12.2-arm64-g named sibookpro.home
>> by blaise Thu Apr 20 21:14:40 2023
>> [0]PETSC ERROR: Configure options
>> --CFLAGS="-Wimplicit-function-declaration -Wunused -Wuninitialized"
>> --FFLAGS="-ffree-line-length-none -fallow-argument-mismatch -Wunused
>> -Wuninitialized" --download-exodusii=1 --download-hdf5=1
>> --download-netcdf=1 --download-ml=1 --download-pnetcdf=1 --download-zlib=1
>> --with-debugging=1 --with-exodusii-fortran-bindings
>> --with-shared-libraries=1 --with-x11=1
>> [0]PETSC ERROR: #1 DMGetDS() at
>> /opt/HPC/petsc-main/src/dm/interface/dm.c:5419
>> [0]PETSC ERROR: #2 DMPlexPreallocateOperator() at
>> /opt/HPC/petsc-main/src/dm/impls/plex/plexpreallocate.c:710
>> [0]PETSC ERROR: #3 DMCreateMatrix_Plex() at
>> /opt/HPC/petsc-main/src/dm/impls/plex/plex.c:2662
>> [0]PETSC ERROR: #4 DMCreateMatrix() at
>> /opt/HPC/petsc-main/src/dm/interface/dm.c:1476
>> [0]PETSC ERROR: #5 main() at ex98.c:92
>> [0]PETSC ERROR: PETSc Option Table entries:
>> [0]PETSC ERROR: -dm_mat_view (source: command line)
>> [0]PETSC ERROR: -i
>> /Users/blaise/Development/mef90/mef90-dmplex/TestMeshes/SquareFaceSet.msh
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> Abort(73) on node 0 (rank 0 in comm 16): application called
>> MPI_Abort(MPI_COMM_SELF, 73) - process 0
>> Do I now need to use DS in order to use duplex and sections?
>> Regards,
>> Blaise
>>>> Canada Research Chair in Mathematical and Computational Aspects of Solid
>> Mechanics (Tier 1)
>> Professor, Department of Mathematics & Statistics
>> Hamilton Hall room 409A, McMaster University
>> 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
>> https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
>> <ex98.c>
>> Mechanics (Tier 1)
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> Mechanics (Tier 1)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230423/8f4de64f/attachment.html>
