[petsc-dev] Is the petsc4py build broken?
Sun Apr 16 13:50:28 CDT 2023
On Sun, 16 Apr 2023, Matthew Knepley wrote:
> On Sun, Apr 16, 2023 at 12:34 AM Pierre Jolivet <pierre.jolivet at lip6.fr>
> wrote:
> > petsc4py build is not broken, but maybe it is not future-proof and can’t
> > handle Cython 3.0.0b2 (or there is a regression in Cython).
> > Could you downgrade your Cython (to an actual release and not a beta) and
> > see if the error persists?
> You are correct. However, I think this is a bug in the petsc4py install
> now. I had deleted my Cython, and it was fetched automatically.
Strange. I'm getting:
[balay at pj01 petsc]$ python3 -m pip install --user cython
Collecting cython
  Using cached Cython-0.29.34-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.manylinux_2_24_x86_64.whl (1.9 MB)
Installing collected packages: cython
Successfully installed cython-0.29.34
> I think we need to change
>   src/binding/petsc4py/conf/confpetsc.py:133
> I just changed '>=' to '==', but maybe we just put a '< 3' since it is
> incompatible with the 3.0.0.b2 which setuptools
> is automatically bringing down.
Can you create an MR [to release]? I think Lisandro would have to check on this [I guess support both CYTHON_MIN and CYTHON_MAX]
Satish
>   Thanks,
>     Matt
> > Thanks,
> > Pierre
> > > On 16 Apr 2023, at 12:25 AM, Satish Balay via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> > > Works for me with latest main - so I'm not sure whats going on here..
> > > Is this reproducible in a clean clone? Also - are you using mpi4py in
> > this build?
> > > https://gitlab.com/petsc/petsc/-/issues/1359
> > > [this issue looks different though..]
> > > Satish
> > > *** Building petsc4py ***
> > > running build
> > > running build_src
> > > using Cython 0.29.33
> > > cythonizing 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
> > > running build_py
> > > creating build
> > > creating build/lib.linux-x86_64-cpython-311
> > > creating build/lib.linux-x86_64-cpython-311/petsc4py
> > > copying src/petsc4py/PETSc.py ->
> > > copying src/petsc4py/__main__.py ->
> > > copying src/petsc4py/__init__.py ->
> > > creating build/lib.linux-x86_64-cpython-311/petsc4py/lib
> > > On Sat, 15 Apr 2023, Matthew Knepley wrote:
> > >> I get
> > >> running build
> > >> running build_src
> > >> removing Cython 0.29.30 from sys.modules
> > >> fetching build requirement 'Cython >= 0.29.32'
> > >> Searching for Cython>=0.29.32
> > >> Best match: Cython 3.0.0b2
> > >> Processing Cython-3.0.0b2-py3.8-macosx-10.9-x86_64.egg
> > >> Using
> > /PETSc3/petsc/petsc-dev/src/binding/petsc4py/.eggs/Cython-3.0.0b2-py3.8-macosx-10.9-x86_64.egg
> > >> using Cython 3.0.0b2
> > >> /PETSc3/petsc/petsc-dev/src/binding/petsc4py/conf/cythonize.py: No such
> > >> file or directory: 'petsc4py/PETSc.pyx'
> > >> error: Cython failure: 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
> > >> **************************ERROR*************************************
> > >> Error building petsc4py.
> > >>  Thanks,
> > >>     Matt
