[petsc-dev] Is the petsc4py build broken?
Sat Apr 15 11:43:46 CDT 2023
I get
*** Building petsc4py ***
running build
running build_src
removing Cython 0.29.30 from sys.modules
fetching build requirement 'Cython >= 0.29.32'
Searching for Cython>=0.29.32
Best match: Cython 3.0.0b2
Processing Cython-3.0.0b2-py3.8-macosx-10.9-x86_64.egg
Using
/PETSc3/petsc/petsc-dev/src/binding/petsc4py/.eggs/Cython-3.0.0b2-py3.8-macosx-10.9-x86_64.egg
using Cython 3.0.0b2
cythonizing 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
/PETSc3/petsc/petsc-dev/src/binding/petsc4py/conf/cythonize.py: No such
file or directory: 'petsc4py/PETSc.pyx'
error: Cython failure: 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
**************************ERROR*************************************
Error building petsc4py.
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230415/e55b9036/attachment.html>
