[petsc-dev] Kokkos/Crusher perforance
Mark Adams mfadams at lbl.gov
Sun Jan 23 07:58:10 CST 2022
On Sat, Jan 22, 2022 at 6:22 PM Barry Smith <bsmith at petsc.dev> wrote:
>    I cleaned up Mark's last run and put it in a fixed-width font. I
> realize this may be too difficult but it would be great to have identical
> runs to compare with on Summit.
I was planning on running this on Perlmutter today, as well as some sanity
checks like all GPUs are being used. I'll try PetscDeviceView.
Junchao modified the timers and all GPU > CPU now, but he seemed to move
the timers more outside and Barry wants them tight on the "kernel".
I think Junchao is going to work on that so I will hold off.
(I removed the the Kokkos wait stuff and seemed to run a little faster but
I am not sure how deterministic the timers are, and I did a test with GAMG
and it was fine.)
>    As Jed noted Scatter takes a long time but the pack and unpack take no
> time? Is this not timed if using Kokkos?
> --- Event Stage 2: KSP Solve only
> MatMult              400 1.0 8.8003e+00 1.1 1.06e+11 1.0 2.2e+04 8.5e+04
> 0.0e+00  2 55 61 54  0  70 91100100   95,058   132,242      0 0.00e+00    0
> 0.00e+00 100
> VecScatterBegin      400 1.0 1.3391e+00 2.6 0.00e+00 0.0 2.2e+04 8.5e+04
> 0.0e+00  0  0 61 54  0   7  0100100        0         0      0 0.00e+00    0
> 0.00e+00  0
> VecScatterEnd        400 1.0 1.3240e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   9  0  0  0        0         0      0 0.00e+00    0
> 0.00e+00  0
> SFPack               400 1.0 1.8276e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0        0         0      0 0.00e+00    0
> 0.00e+00  0
> SFUnpack             400 1.0 6.2653e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> KSPSolve               2 1.0 1.2540e+01 1.0 1.17e+11 1.0 2.2e+04 8.5e+04
> 1.2e+03  3 60 61 54 60 100100100      73,592   116,796      0 0.00e+00    0
> 0.00e+00 100
> VecTDot              802 1.0 1.3551e+00 1.2 3.36e+09 1.0 0.0e+00 0.0e+00
> 8.0e+02  0  2  0  0 40  10  3  0      19,627    52,599      0 0.00e+00    0
> 0.00e+00 100
> VecNorm              402 1.0 9.0151e-01 2.2 1.69e+09 1.0 0.0e+00 0.0e+00
> 4.0e+02  0  1  0  0 20   5  1  0  0   14,788   125,477      0 0.00e+00    0
> 0.00e+00 100
> VecAXPY              800 1.0 8.2617e-01 1.0 3.36e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  2  0  0  0   7  3  0  0   32,112    61,644      0 0.00e+00    0
> 0.00e+00 100
> VecAYPX              398 1.0 8.1525e-01 1.6 1.67e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   5  1  0  0   16,190    20,689      0 0.00e+00    0
> 0.00e+00 100
> VecPointwiseMult     402 1.0 3.5694e-01 1.0 8.43e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   3  1  0  0   18,675    38,633      0 0.00e+00    0
> 0.00e+00 100
> On Jan 22, 2022, at 12:40 PM, Mark Adams <mfadams at lbl.gov> wrote:
> And I have a new MR with if you want to see what I've done so far.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220123/e2167936/attachment-0001.html>
