[petsc-dev] Speeding up building docs
Barry Smith bsmith at petsc.dev
Fri Jan 14 15:48:06 CST 2022
  Patrick,
    Building docs is so much faster now, thanks! But when I get
Assuming that the classic docs in /Users/barrysmith/Src/petsc/doc/_build_classic are current
it still does
    Copying classic docs from conf.py
Copying directory /Users/barrysmith/Src/petsc/doc/_build_classic/docs/manualpages to /Users/barrysmith/Src/petsc/doc/_build/html/docs/manualpages
Copying directory /Users/barrysmith/Src/petsc/doc/_build_classic/include to /Users/barrysmith/Src/petsc/doc/_build/html/include
Copying directory /Users/barrysmith/Src/petsc/doc/_build_classic/src to /Users/barrysmith/Src/petsc/doc/_build/html/src
    Fixing relative links from conf.py
    Adding version to classic man pages, from conf.py
Would it be possible to rig the dependencies so that the copies and fixes are only done when needed, instead of every time?
Thanks
Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220114/008d8f42/attachment-0001.html>
