[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
    Eric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Wed Mar  3 08:22:13 CST 2021
Hi Pierre,
On 2021-03-03 2:42 a.m., Pierre Jolivet wrote:
>> If it ends that there is a problem combining MKL + openMP that relies
>> on linking configuration for example, should it be a good thing to
>> have this (--with-openmp=1) tested into the pipelines (with external
>> packages of course)?
> As Barry said, there is not much (if any) OpenMP in PETSc.
> There is however some workers with the MKL (+ Intel compilers) turned
> on, but I don’t think we test MKL + GNU compilers (which I feel like
> is a very niche combination, hence not really worth testing, IMHO).
Ouch, this is my almost my personal working configuration and for most
of our users too... and it worked well until I activated the OpenMP thing...
We had good reasons to work with g++ or clang++ instead of intel compilers:
- It is mandatory to pay to work with an intel compiler (didn't looked
at OneAPI licensing yet, but it may have changed?)
- No support of Intel compilers with iceccd (slow recompilation)
- MKL was freely distributed, so it can be used with any compiler
That doesn't mean we don't want to use intel compiler, but maybe we just
want to to a specific delivery with it but continue to develop with g++
or clang++ (my personal choice).
But I understand it is less straightforward to combine gcc and MKL than
using native Intel tool-chain....
>> Does the guys who maintain all these libs are reading petsc-dev? ;)
> I don’t think they are, but don’t worry, we do forward the appropriate
> messages to them :)
> About yesterday’s failures…
> 1) I cannot reproduce any of the PCHYPRE/PCBDDC/PCHPDDM errors (sorry
> I didn’t bother putting the SuperLU_DIST tarball on my cluster)
Hmmm, maybe my environment variables may play a role into this?
for comparisons considerations, we explicitly set:
export MKL_CBWR=COMPATIBLE
export MKL_NUM_THREADS=1
but it would be surprising it helps reproduce a problem: they usually
stabilize results...
> 2) I can reproduce the src/mat/tests/ex242.c error (which explicitly
> uses ScaLAPACK, none of the above PC uses it explicitly, except
> PCBDDC/PCHPDDM when using MUMPS on “big” problems where root nodes are
> factorized using ScaLAPACK, see -mat_mumps_icntl_13)
> 3) I’m seeing that both on your machine and mine, PETSc BuildSystem
> insist on linking libmkl_blacs_intelmpi_lp64.so even though we supply
> explicitly libmkl_blacs_openmpi_lp64.so
> This for example yields a wrong Makefile.inc for MUMPS:
> $ cat
> arch-linux2-c-opt-ompi/externalpackages/MUMPS_5.3.5/Makefile.inc|grep
> blacs
> SCALAP  = […] -lmkl_blacs_openmpi_lp64
> LIBBLAS = […] -lmkl_blacs_intelmpi_lp64 -lgomp -ldl -lpthread -lm […]
> Despite what Barry says, I think PETSc is partially to blame as well
> (why use libmkl_blacs_intelmpi_lp64.so even though BuildSystem is
> capable of detecting we are using OpenMPI).
> I’ll try to fix this to see if it solves 2).
Okay, that's a very nice finding!!!  Hope it will be "fixable" easily!
Merci,
Eric
> Thanks,
> Pierre
> http://joliv.et/irene-rome-configure.log
> <http://joliv.et/irene-rome-configure.log>
> $ /usr/bin/gmake -f gmakefile test test-fail=1
> Using MAKEFLAGS: test-fail=1
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_baij.counts
>  ok snes_tutorials-ex12_quad_hpddm_reuse_baij
>  ok diff-snes_tutorials-ex12_quad_hpddm_reuse_baij
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex50_tut_2.counts
>  ok ksp_ksp_tutorials-ex50_tut_2 # SKIP PETSC_HAVE_SUPERLU_DIST
> requirement not met
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_hypre.counts
>  ok snes_tutorials-ex56_hypre
>  ok diff-snes_tutorials-ex56_hypre
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_elas.counts
>  ok snes_tutorials-ex17_3d_q3_trig_elas
>  ok diff-snes_tutorials-ex17_3d_q3_trig_elas
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij.counts
>  ok snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
>  ok diff-snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_tri_parmetis_hpddm_baij.counts
>  ok snes_tutorials-ex12_tri_parmetis_hpddm_baij
>  ok diff-snes_tutorials-ex12_tri_parmetis_hpddm_baij
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_tut_3.counts
>  ok snes_tutorials-ex19_tut_3
>  ok diff-snes_tutorials-ex19_tut_3
>         TEST arch-linux2-c-opt-ompi/tests/counts/mat_tests-ex242_3.counts
> not ok mat_tests-ex242_3 # Error code: 137
> #[1]PETSC ERROR:
> #[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> #[1]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> #[1]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> #[1]PETSC ERROR: or try http://valgrind.org <http://valgrind.org> on
> GNU/linux and Apple Mac OS X to find memory corruption errors
> #[1]PETSC ERROR: configure using --with-debugging=yes, recompile,
> link, and run
> #[1]PETSC ERROR: to get more information on the crash.
> #[1]PETSC ERROR: --------------------- Error Message
> #[1]PETSC ERROR: Signal received
> #[1]PETSC ERROR: See
> <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> shooting.
> #[1]PETSC ERROR: Petsc Development GIT revision:
> v3.14.4-733-g7ab9467ef9  GIT Date: 2021-03-02 16:15:11 +0000
> #[2]PETSC ERROR:
> #[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> #[2]PETSC ERROR: Try option -start_in_debugger or
> #[2]PETSC ERROR: or see
> #[2]PETSC ERROR: or try http://valgrind.org <http://valgrind.org> on
> #[2]PETSC ERROR: configure using --with-debugging=yes, recompile,
> link, and run
> #[2]PETSC ERROR: to get more information on the crash.
> #[2]PETSC ERROR: --------------------- Error Message
> #[2]PETSC ERROR: Signal received
> #[2]PETSC ERROR: See
> shooting.
> #[2]PETSC ERROR: Petsc Development GIT revision:
> #[2]PETSC ERROR:
> /ccc/work/cont003/rndm/rndm/petsc/arch-linux2-c-opt-ompi/tests/mat/tests/runex242_3/../ex242
> on a arch-linux2-c-opt-ompi named irene4047 by jolivetp Wed Mar  3
> 08:21:20 2021
> #[2]PETSC ERROR: Configure options --download-hpddm
> --download-hpddm-commit=origin/main --download-hypre --download-metis
> --download-mumps --download-parmetis --download-ptscotch
> --download-slepc --download-slepc-commit=origin/main --download-tetgen
> --known-mpi-c-double-complex --known-mpi-int64_t
> --known-mpi-long-double --with-avx512-kernels=1
> --with-blaslapack-dir=/ccc/products/mkl-19.0.5.281/intel--19.0.5.281__openmpi--4.0.1/default/19.0.5.281/mkl/lib/intel64
> --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpifort
> --with-fortran-bindings=0 --with-make-np=40
> --with-mkl_cpardiso-dir=/ccc/products/mkl-19.0.5.281/intel--19.0.5.281__openmpi--4.0.1/default/19.0.5.281
> --with-mkl_cpardiso=1
> --with-mkl_pardiso-dir=/ccc/products/mkl-19.0.5.281/intel--19.0.5.281__openmpi--4.0.1/default/19.0.5.281/mkl
> --with-mkl_pardiso=1 --with-mpiexec=ccc_mprun --with-openmp=1
> --with-packages-download-dir=/ccc/cont003/home/enseeiht/jolivetp/Dude/externalpackages/
> --with-scalapack-include=/ccc/products/mkl-19.0.5.281/intel--19.0.5.281__openmpi--4.0.1/default/19.0.5.281/mkl/include
> --with-scalapack-lib="[/ccc/products/mkl-19.0.5.281/intel--19.0.5.281__openmpi--4.0.1/default/19.0.5.281/mkl/lib/intel64/libmkl_scalapack_lp64.so,/ccc/products/mkl-19.0.5.281/intel--19.0.5.281__openmpi--4.0.1/default/19.0.5.281/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.so]"
> --with-scalar-type=real --with-x=0 COPTFLAGS="-O3 -fp-model fast
> -mavx2" CXXOPTFLAGS="-O3 -fp-model fast -mavx2" FOPTFLAGS="-O3
> -fp-model fast -mavx2" PETSC_ARCH=arch-linux2-c-opt-ompi
> #[2]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> #[2]PETSC ERROR: Run with -malloc_debug to check if memory corruption
> is causing the crash.
> #[1]PETSC ERROR:
> 08:21:20 2021
> #[1]PETSC ERROR: Configure options --download-hpddm
> #[1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> #[1]PETSC ERROR: Run with -malloc_debug to check if memory corruption
> #MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
> #with errorcode 50176059.
> #NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> #You may or may not see output from other processes, depending on
> #exactly when Open MPI kills them.
> #MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> #srun: Job step aborted: Waiting up to 302 seconds for job step to finish.
> #slurmstepd-irene4047: error: *** STEP 1374176.36 ON irene4047
> CANCELLED AT 2021-03-03T08:21:20 ***
> #srun: error: irene4047: task 0: Killed
> #srun: error: irene4047: tasks 1-2: Exited with exit code 16
>  ok mat_tests-ex242_3 # SKIP Command failed so no diff
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_vlap.counts
>  ok snes_tutorials-ex17_3d_q3_trig_vlap
>  ok diff-snes_tutorials-ex17_3d_q3_trig_vlap
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre.counts
>  ok snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
>  ok diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex49_hypre_nullspace.counts
>  ok ksp_ksp_tutorials-ex49_hypre_nullspace
>  ok diff-ksp_ksp_tutorials-ex49_hypre_nullspace
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/ts_tutorials-ex18_p1p1_xper_ref.counts
>  ok ts_tutorials-ex18_p1p1_xper_ref
>  ok diff-ts_tutorials-ex18_p1p1_xper_ref
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/ts_tutorials-ex18_p1p1_xyper_ref.counts
>  ok ts_tutorials-ex18_p1p1_xyper_ref
>  ok diff-ts_tutorials-ex18_p1p1_xyper_ref
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre.counts
>  ok snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
>  ok diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
>         TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex64_1.counts
>  ok ksp_ksp_tutorials-ex64_1 # SKIP PETSC_HAVE_SUPERLU_DIST
> requirement not met
>> On 3 Mar 2021, at 6:21 AM, Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca
>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>> Just started a discussion on the side:
>> https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Intel-MKL-Link-Line-Advisor-as-external-tool/m-p/1260895#M30974
>> Eric
>> On 2021-03-02 3:50 p.m., Pierre Jolivet wrote:
>>> Hello Eric,
>>> src/mat/tests/ex237.c is a recent test with some code paths that
>>> should be disabled for “old” MKL versions. It’s tricky to check
>>> directly in the source (we do check in BuildSystem) because there is
>>> no such thing as PETSC_PKG_MKL_VERSION_LT, but I guess we can change
>>> if defined(PETSC_HAVE_MKL) to if defined(PETSC_HAVE_MKL) &&
>>> defined(PETSC_HAVE_MKL_SPARSE_OPTIMIZE), I’ll make a MR, thanks for
>>> reporting this.
>>> For the other issues, I’m sensing this is a problem with gomp +
>>> intel_gnu_thread, but this is pure speculation… sorry.
>>> I’ll try to reproduce some of these problems if you are not given a
>>> more meaningful answer.
>>> Thanks,
>>> Pierre
>>>> On 2 Mar 2021, at 9:14 PM, Eric Chamberland
>>>> Hi,
>>>> It all started when I wanted to test PETSC/CUDA compatibility for
>>>> our code.
>>>> I had to activate --with-openmp to configure with --with-cuda=1
>>>> successfully.
>>>> I then saw that PETSC_HAVE_OPENMP  is used at least in MUMPS (and
>>>> some other places).
>>>> So, I configured and tested petsc with openmp activated, without CUDA.
>>>> The first thing I see is that our code CI pipelines now fails for
>>>> many tests.
>>>> After looking deeper, it seems that PETSc itself fails many tests
>>>> when I activate openmp!
>>>> Here are all the configurations I have results for, after/before
>>>> activating OpenMP for PETSc:
>>>> For petsc/master + OpenMPI 4.0.4 + MKL 2019.4.243:
>>>> With OpenMP=1
>>>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_configure.log
>>>> #   Summary
>>>> # FAILED snes_tutorials-ex12_quad_hpddm_reuse_baij diff-ksp_ksp_tests-ex33_superlu_dist_2 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1 ksp_ksp_tutorials-ex50_tut_2 diff-ksp_ksp_tests-ex33_superlu_dist diff-snes_tutorials-ex56_hypre snes_tutorials-ex17_3d_q3_trig_elas snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij ksp_ksp_tutorials-ex5_superlu_dist_3 ksp_ksp_tutorials-ex5f_superlu_dist snes_tutorials-ex12_tri_parmetis_hpddm_baij diff-snes_tutorials-ex19_tut_3 mat_tests-ex242_3 snes_tutorials-ex17_3d_q3_trig_vlap ksp_ksp_tutorials-ex5f_superlu_dist_3 snes_tutorials-ex19_superlu_dist diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre diff-ksp_ksp_tutorials-ex49_hypre_nullspace ts_tutorials-ex18_p1p1_xper_ref ts_tutorials-ex18_p1p1_xyper_ref snes_tutorials-ex19_superlu_dist_2 ksp_ksp_tutorials-ex5_superlu_dist_2 diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre ksp_ksp_tutorials-ex64_1 ksp_ksp_tutorials-ex5_superlu_dist ksp_ksp_tutorials-ex5f_superlu_dist_2
>>>> # success 8275/10003 tests (82.7%)
>>>> #*failed 33/10003*  tests (0.3%)
>>>> With OpenMP=0
>>>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_configure.log
>>>> #   Summary
>>>> # FAILED tao_constrained_tutorials-tomographyADMM_6 snes_tutorials-ex17_3d_q3_trig_elas mat_tests-ex242_3 snes_tutorials-ex17_3d_q3_trig_vlap tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_5
>>>> # success 8262/9983 tests (82.8%)
>>>> #*failed 6/9983*  tests (0.1%)
>>>> For OpenMPI 3.1.x/master:
>>>> With OpenMP=1:
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_configure.log
>>>> #   Summary
>>>> # FAILED mat_tests-ex242_3 mat_tests-ex242_2 diff-mat_tests-ex219f_1 diff-dm_tutorials-ex11f90_1 ksp_ksp_tutorials-ex5_superlu_dist_3 diff-ksp_ksp_tutorials-ex49_hypre_nullspace ksp_ksp_tutorials-ex5f_superlu_dist_3 snes_tutorials-ex17_3d_q3_trig_vlap diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre diff-snes_tutorials-ex19_tut_3 diff-snes_tutorials-ex56_hypre diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_4 tao_constrained_tutorials-tomographyADMM_6 diff-tao_constrained_tutorials-toyf_1
>>>> # success 8142/9765 tests (83.4%)
>>>> #*failed 16/9765*  tests (0.2%)
>>>> With OpenMP=0:
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_configure.log
>>>> #   Summary
>>>> # FAILED mat_tests-ex242_3 mat_tests-ex242_2 diff-mat_tests-ex219f_1 diff-dm_tutorials-ex11f90_1 ksp_ksp_tutorials-ex56_2 snes_tutorials-ex17_3d_q3_trig_vlap tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_4 diff-tao_constrained_tutorials-toyf_1
>>>> # success 8151/9767 tests (83.5%)
>>>> #*failed 9/9767*  tests (0.1%)
>>>> For OpenMPI 4.0.x/master:
>>>> With OpenMP=1:
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_configure.log
>>>> # FAILED snes_tutorials-ex17_3d_q3_trig_elas snes_tutorials-ex19_hypre ksp_ksp_tutorials-ex56_2 tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_5 mat_tests-ex242_3 ksp_ksp_tutorials-ex55_hypre ksp_ksp_tutorials-ex5_superlu_dist_2 tao_constrained_tutorials-tomographyADMM_6 snes_tutorials-ex56_hypre snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre ksp_ksp_tutorials-ex5f_superlu_dist_3 ksp_ksp_tutorials-ex34_hyprestruct diff-ksp_ksp_tutorials-ex49_hypre_nullspace snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre ksp_ksp_tutorials-ex5f_superlu_dist ksp_ksp_tutorials-ex5f_superlu_dist_2 ksp_ksp_tutorials-ex5_superlu_dist snes_tutorials-ex19_tut_3 snes_tutorials-ex19_superlu_dist ksp_ksp_tutorials-ex50_tut_2 snes_tutorials-ex17_3d_q3_trig_vlap ksp_ksp_tutorials-ex5_superlu_dist_3 snes_tutorials-ex19_superlu_dist_2 tao_constrained_tutorials-tomographyADMM_4 ts_tutorials-ex26_2
>>>> # success 8125/9753 tests (83.3%)
>>>> #*failed 26/9753*  tests (0.3%)
>>>> With OpenMP=0
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_configure.log
>>>> # success 8174/9777 tests (83.6%)
>>>> #*failed 1/9777*  tests (0.0%)
>>>> Is that known and normal?
>>>> In all cases, I am using MKL and I suspect it  may come from
>>>> there... :/
>>>> I also saw a second problem, "make test" fails to compile petsc
>>>> examples on older versions of MKL (but that's less important for
>>>> me, I just upgraded to OneAPI to avoid this, but you may want to know):
>>>> https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_make_test.log
>>>> https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_configure.log
>>>> Thanks,
>>>> Eric
>>>> Eric Chamberland, ing., M. Ing
>>>> Professionnel de recherche
>>>> GIREF/Université Laval
>>>> (418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210303/d4b938ca/attachment-0001.html>
