[petsc-dev] help on Summit
Mark Adams mfadams at lbl.gov
Mon Aug 30 09:34:45 CDT 2021
I was running fine this AM and am bouncing between modules to help two apps
(ECP milestone season) at the same time and something broke. I did update
main and I get the same error in main and a hypre branch of Stefano's.
I started with a clean build and checked my modules...
Any ideas?
       CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o
          CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o
       CUDAC
arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o
   CUDAC.dep
       CUDAC
arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o
   CUDAC.dep
       CUDAC
arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o
   CUDAC.dep
       CUDAC
arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o
   CUDAC.dep
       CUDAC
arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
   CUDAC.dep
       CUDAC
arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o
   CUDAC.dep
       CUDAC
arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o
   CUDAC.dep
     CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3
arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0):
multiple definition of
`Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking'
arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44):
first defined here
/usr/bin/ld: link errors found, deleting executable
`arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3'
collect2: error: ld returned 1 exit status
gmake[3]: *** [gmakefile:113:
arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1
gmake[2]: ***
[/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs]
Error 2
**************************ERROR*************************************
  Error during compile, check
arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log
  Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov
gmake[1]: *** [makefile:40: all] Error 1
make: *** [GNUmakefile:9: all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/641b6040/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/641b6040/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/641b6040/attachment-0003.obj>
