[petsc-dev] -info from just one process?
Barry Smith bsmith at petsc.dev
Thu Apr 22 12:45:54 CDT 2021
  It would be straightforward to add an option to -info to output only from a particular MPI_COMM_WORLD global rank.
  Maybe an extra :rank at the end of the info options?
  Open 128k files is nuts.
  Barry
> On Apr 22, 2021, at 11:14 AM, Mark Adams <mfadams at lbl.gov> wrote:
> OK, so -info out.%p would do what I asked. Alas, what I really need it to reduce the output with 128K processes.
> Thanks,
> On Thu, Apr 22, 2021 at 11:54 AM Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>> On 22 Apr 2021, at 5:33 PM, Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
>> Not out of the box no. There is -info ::self which makes info only print from calls made on PETSC_COMM_SELF, but I don’t think that’s what you want. Best advice would be to print to a file and grep the file for any lines starting with the rank number you want.
> There is no need for grep, IMHO, just do -info file and then open file.%p
> Thanks,
> Pierre
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>>> On Apr 22, 2021, at 10:16, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>> Can I make -info only print from one process?
>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210422/e2d72aa4/attachment.html>
