[petsc-dev] Question about MPICH device we use
    Jeff Hammond
    jeff.science at gmail.com
    Thu Jul 23 22:34:33 CDT 2020
Open-MPI refuses to let users over subscribe without an extra flag to
mpirun. I think Intel MPI has an option for blocking poll that supports
oversubscription “nicely”. MPICH might have a “no local” option that
disables shared memory, in which case nemesis over libfabric with the
sockets or TCP provider _might_ do the right thing. But you should ask
MPICH people for details.
Jeff
On Thu, Jul 23, 2020 at 12:40 PM Jed Brown <jed at jedbrown.org> wrote:
> I think we should default to ch3:nemesis when --download-mpich, and only
> do ch3:sock when requested (which we would do in CI).
> Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > Primarily because ch3:sock performance does not degrade in oversubscribe
> mode - which is developer friendly - i.e on your laptop.
> > And folks doing optimized runs should use a properly tuned MPI for their
> setup anyway.
> > In this case --download-mpich-device=ch3:nemesis is likely appropriate
> if using --download-mpich [and not using a separate/optimized MPI]
> > Having defaults that satisfy all use cases is not practical.
> > Satish
> > On Wed, 22 Jul 2020, Matthew Knepley wrote:
> >> We default to ch3:sock. Scott MacLachlan just had a long thread on the
> >> Firedrake list where it ended up that reconfiguring using ch3:nemesis
> had a
> >> 2x performance boost on his 16-core proc, and noticeable effect on the 4
> >> core speedup.
> >> Why do we default to sock?
> >>   Thanks,
> >>      Matt
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200723/5e803d76/attachment.html>
