[petsc-dev] AVX kernels, old gcc, still broken
    Balay, Satish
    balay at mcs.anl.gov
    Thu Oct 24 17:40:31 CDT 2019
I'm curious why this issue comes up for you. The code was unrelated to --with-avx512-kernels=0 option.
Its relying on __AVX512F__and PETSC_HAVE_IMMINTRIN_H flags. And
assumes immintrin.h has a definition for _mm512_reduce_add_pd()
Is the flag __AVX512F__ always set on your machine by gcc?
And does this change based on the hardware? I just tried this build
[same os/compiler] on "Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz" - and
can't reproduce the issue.
I do see _mm512_reduce_add_pd is missing from immintrin.h - but the
flag __AVX512F__ is not set for me.
Satish
balay at compute004^~/junk $ cat xyz.c
#if defined __AVX512F__
#error "avx512f flag set"
#endif
#include <immintrin.h>
balay at compute004^~/junk $ gcc xyz.c -c
balay at compute004^~/junk $ gcc xyz.c -E |grep _mm512_reduce_add_pd
balay at compute004^~/junk $ gcc --version
gcc (Ubuntu 5.4.0-6ubuntu1~16.04.10) 5.4.0 20160609
On Fri, 25 Oct 2019, Lisandro Dalcin via petsc-dev wrote:
> Yes, that should work, I coded it myself to workaround the issue, but you
> were faster than me. Thanks!
> On Thu, 24 Oct 2019 at 22:00, Zhang, Hong <hongzhang at anl.gov> wrote:
> > Hi Lisandro,
> > Can you please check if the following patch fixes the problem? I will
> > create a MR.
> > diff --git a/src/mat/impls/aij/seq/aijperm/aijperm.c
> > b/src/mat/impls/aij/seq/aijperm/aijperm.c
> > index 577dfc6713..568535117a 100644
> > --- a/src/mat/impls/aij/seq/aijperm/aijperm.c
> > +++ b/src/mat/impls/aij/seq/aijperm/aijperm.c
> > @@ -12,7 +12,7 @@
> >  #include <../src/mat/impls/aij/seq/aij.h>
> > -#if defined(PETSC_HAVE_IMMINTRIN_H) && defined(__AVX512F__) &&
> > defined(PETSC_USE_REAL_DOUBLE) && !defined(PETSC_USE_COMPLEX) &&
> > !defined(PETSC_USE_64BIT_INDICES)
> > +#if defined(PETSC_USE_AVX512_KERNELS) && defined(PETSC_HAVE_IMMINTRIN_H)
> > && defined(__AVX512F__) && defined(PETSC_USE_REAL_DOUBLE) &&
> > !defined(PETSC_USE_COMPLEX) && !defined(PETSC_USE_64BIT_INDICES) &&
> > !defined(PETSC_SKIP_IMMINTRIN_H_CUDAWORKAROUND)
> >  #if !defined(_MM_SCALE_8)
> > @@ -301,7 +301,7 @@ PetscErrorCode MatMult_SeqAIJPERM(Mat A,Vec xx,Vec yy)
> >  #if !(defined(PETSC_USE_FORTRAN_KERNEL_MULTAIJPERM) &&
> > defined(notworking))
> >    PetscInt          i,j;
> >  #endif
> >    __m512d           vec_x,vec_y,vec_vals;
> >    __m256i           vec_idx,vec_ipos,vec_j;
> >    __mmask8           mask;
> > @@ -401,7 +401,7 @@ PetscErrorCode MatMult_SeqAIJPERM(Mat A,Vec xx,Vec yy)
> >  #pragma _CRI prefervector
> >  #endif
> >              vec_y = _mm512_setzero_pd();
> >              ipos = ip[i];
> >              for (j=0; j<(nz>>3); j++) {
> > @@ -436,7 +436,7 @@ PetscErrorCode MatMult_SeqAIJPERM(Mat A,Vec xx,Vec yy)
> >             * worthwhile to vectorize across the rows, that is, to do the
> >             * matvec by operating with "columns" of the chunk. */
> >            for (j=0; j<nz; j++) {
> >              vec_j = _mm256_set1_epi32(j);
> >              for (i=0; i<((isize>>3)<<3); i+=8) {
> >                vec_y    = _mm512_loadu_pd(&yp[i]);
> > Thanks,
> > Hong
> > On Oct 24, 2019, at 2:47 PM, Lisandro Dalcin via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> > This is with master, but I bet the issue is also in maint.
> > * Running on Ubuntu 16
> > $ uname -a
> > Linux flamingo 4.4.0-104-generic #127-Ubuntu SMP Mon Dec 11 12:16:42 UTC
> > 2017 x86_64 x86_64 x86_64 GNU/Linux
> > * With system gcc 5.4
> > $ mpicc -show
> > /usr/bin/gcc-5
> > -I/sw/workstations/apps/linux-ubuntu16.04-x86_64/mpich/3.3.1/gcc-5.4.0/nvejoe25snmak6a7fnjghabxjukjkuiu/include
> > -L/sw/workstations/apps/linux-ubuntu16.04-x86_64/mpich/3.3.1/gcc-5.4.0/nvejoe25snmak6a7fnjghabxjukjkuiu/lib
> > -Wl,-rpath
> > -Wl,/sw/workstations/apps/linux-ubuntu16.04-x86_64/mpich/3.3.1/gcc-5.4.0/nvejoe25snmak6a7fnjghabxjukjkuiu/lib
> > -lmpi
> > $ mpicc --version
> > gcc-5 (Ubuntu 5.4.0-6ubuntu1~16.04.11) 5.4.0 20160609
> > Copyright (C) 2015 Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions.  There is NO
> > warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> > * PETSc configured to NOT USE AVX512 kernels
> > $ grep avx arch-gnu-opt/lib/petsc/conf/reconfigure-arch-gnu-opt.py
> >     '--with-avx512-kernels=0',
> > * Bang!
> > $ touch src/mat/impls/aij/seq/aijperm/aijperm.c
> > $ make -f gmakefile
> > Use "/usr/bin/make V=1" to see verbose compile lines, "/usr/bin/make V=0"
> > to suppress.
> >           CC arch-gnu-opt/obj/mat/impls/aij/seq/aijperm/aijperm.o
> > /home/dalcin/Devel/petsc/src/mat/impls/aij/seq/aijperm/aijperm.c: In
> > function ‘MatMult_SeqAIJPERM’:
> > /home/dalcin/Devel/petsc/src/mat/impls/aij/seq/aijperm/aijperm.c:426:22:
> > warning: implicit declaration of function ‘_mm512_reduce_add_pd’
> > [-Wimplicit-function-declaration]
> >              yp[i] += _mm512_reduce_add_pd(vec_y);
> > Lisandro Dalcin
> > Research Scientist
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
