[petsc-dev] Remove legacy tests
Jose E. Roman jroman at dsic.upv.es
Wed Sep 5 09:29:01 CDT 2018
It works for us. Thanks.
Jose
> El 5 sept 2018, a las 15:15, Satish Balay <balay at mcs.anl.gov> escribió:
> I pushed the change to balay/remove-Regression.py
> Satish
> On Mon, 3 Sep 2018, Jose E. Roman wrote:
>> We are almost done with migrating SLEPc tests to the new test harness. If you want, you can remove Regression.py from PETSc, as well as any makefile rules that might remain for legacy tests.
>> Jose
