[petsc-dev] MPI I/O tests failing in master after merging my branch
Jed Brown jed at jedbrown.org
Thu Mar 22 07:28:10 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
>> > On Thu, Mar 22, 2018 at 6:15 AM, Lisandro Dalcin <dalcinl at gmail.com>
>> wrote:
>> >> On 22 March 2018 at 12:51, Matthew Knepley <knepley at gmail.com> wrote:
>> >> > On Thu, Mar 22, 2018 at 3:44 AM, Lisandro Dalcin <dalcinl at gmail.com>
>> >> wrote:
>> >> >> ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
>> >> 2018/03/21/examples_master_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
>> >> >> The thing is, PETSc does not currently have a way of mapping a plain
>> C
>> >> >> `int` type to a PETSc datatype. I'm wiling to take the required work
>> >> >> to fix this issue.
>> >> > Is this not what PetscMPIInt is for?
>> >> No, not at all, PetscMPIInt it not even mentioned in the PetscDatatype
>> >> enumeration. The whole PetscDatatype this is kind of messy, and fixing
>> >> it should take some time, and this for sure will no make my h-index
>> >> explode, right?. For now, mapping MPI_INT -> PETSC_ENUM seems
>> >> workaround the issue just fine.
>> > What I meant was, we already have a typedef 'PetscMPIInt' which is
>> supposed
>> > to reproduce MPI_INT, so why not add PETSC_MPI_INT to the PetscDataTypes
>> > rather than map MPI_INT to PetscEnum?
>> https://bitbucket.org/petsc/petsc/issues/188/remove-use-of-petscdatatype
> I agree, but this was about short term fixing.
I guess I'd rather see a quick workaround if someone needs the
capability now instead of expanding an interface that we're trying to
remove.
