[petsc-dev] testing on Titan
Mark Adams mfadams at lbl.gov
Sat Jun 30 07:13:55 CDT 2018
Thanks Rich, I may take you up on your offer but I've handed it over to the
apps. It seems to be working, but I would not be surprised if there are
more problems.
Note, here is something that I heard from ORNL about cray-petsc:
*One of the OLCF consultants sent me this table about testing petsc ex1.f90
using pgi and petsc.*
*It shows the combination*
*pgi 17.5, cray-petsc 3.7.6.2, cudatoolkit 7.5   worked*
*At least they are aware there is a problem.*
On Fri, Jun 29, 2018 at 8:30 PM Richard Tran Mills <rtmills at anl.gov> wrote:
> Hi Mark,
> I've got an OLCF account but don't have access to Titan. Would it be
> helpful for me to apply to get on whatever allocation you are using so I
> can poke around at this stuff? (If so, send me a message off list with
> details of what I should apply for.)
> Hopefully I could get on there faster than it took them to enable me on
> Summit. I had volunteered to help with issues on Summit some time ago, but
> it took so long for them to enable my account on there that I didn't matter
> by then.
> --Richard
> On Fri, Jun 29, 2018 at 7:12 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Thanks all, I knew this but its been a while since I've run on this file
>> setup.
>> On Fri, Jun 29, 2018 at 9:15 AM Seung-Hoe Ku <sku at pppl.gov> wrote:
>>> Try copying files to scratch file system.
>>> Home is not available when executive batch job. Probably interactive
>>> she'll too.
>>> On Fri, Jun 29, 2018 at 7:47 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I can not even run a job here. This is from an interactive shell:
>>>> 64-pgi ex19-batch1:~/petsc/src/snes/examples/tutorials> make
>>>> PETSC_DIR=/autofs/nccs-svm1_home1/adams/petsc PETSC_ARCH=arch-titan-dbg6
>>>> cc -o ex19.o -c -fast -mp
>>>>  -I/autofs/nccs-svm1_home1/adams/petsc/include
>>>> -I/autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/include
>>>> -I/ccs/proj/env003/petscv3.9-dbg64-pgi/include    `pwd`/ex19.c
>>>> cc -fast -mp  -o ex19  ex19.o
>>>> -L/autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/lib
>>>> -Wl,-rpath,/ccs/proj/env003/petscv3.9-dbg64-pgi/lib
>>>> -L/ccs/proj/env003/petscv3.9-dbg64-pgi/lib -lpetsc -lHYPRE -lflapack
>>>> -lfblas -lparmetis -lmetis -lstdc++ -ldl
>>>> /autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/lib/libpetsc.a(dlimpl.o):
>>>> In function `PetscDLOpen':
>>>> /autofs/nccs-svm1_home1/adams/petsc/src/sys/dll/dlimpl.c:54: warning:
>>>> Using 'dlopen' in statically linked applications requires at runtime the
>>>> shared libraries from the glibc version used for linking
>>>> /autofs/nccs-svm1_home1/adams/petsc/arch-titan-dbg64-pgi/lib/libpetsc.a(send.o):
>>>> In function `PetscOpenSocket':
>>>> /autofs/nccs-svm1_home1/adams/petsc/src/sys/classes/viewer/impls/socket/send.c:106:
>>>> warning: Using 'gethostbyname' in statically linked applications requires
>>>> at runtime the shared libraries from the glibc version used for linking
>>>> adams at titan-batch1:~/petsc/src/snes/examples/tutorials> aprun -n 1
>>>> ./ex19
>>>> [NID 02258] 2018-06-29 07:45:09 Exec ./ex19 failed: chdir
>>>> /autofs/nccs-svm1_home1/adams/petsc/src/snes/examples/tutorials No such
>>>> file or directory
>>>> Seung-Hoe runs here, maybe he can give me advice on what is wrong here.
>>>> On Thu, Jun 28, 2018 at 7:53 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>>   1) We need to get this PGI compiler into our regular testing. It
>>>>> doesn't like some Fortran code the other compilers are ok with
>>>>>    2) Mark,  likely you just need to submit the examples manually to
>>>>> run them. cd src/snes/examples/tutorials; make ex19  then use the batch
>>>>> system to submit the example
>>>>>    Barry
>>>>> > On Jun 28, 2018, at 5:35 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> > I am trying to run on Titan and I am having problems running the
>>>>> tests. I get this output. It says it can not find a directory, but I do an
>>>>> ls in after the error and you can see that it is there.
>>>>> > I've attached the logs.
>>>>> > Any ideas?
>>>>> > Thanks,
>>>>> > Mark
>>>>> > adams at titan-login6:~/petsc> make
>>>>> PETSC_DIR=/ccs/proj/env003/petscv3.9-opt64-pgi PETSC_ARCH="" test
>>>>> > Running test examples to verify correct installation
>>>>> > Using PETSC_DIR=/ccs/proj/env003/petscv3.9-opt64-pgi and PETSC_ARCH=
>>>>> > *******************Error detected during compile or
>>>>> link!*******************
>>>>> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> > /ccs/home/adams/petsc/src/snes/examples/tutorials ex19
>>>>>  -I/ccs/proj/env003/petscv3.9-opt64-pgi/include
>>>>> -I/ccs/proj/env003/petscv3.9-opt64-pgi/include    `pwd`/ex19.c
>>>>> -L/ccs/proj/env003/petscv3.9-opt64-pgi/lib
>>>>> -Wl,-rpath,/ccs/proj/env003/petscv3.9-opt64-pgi/lib
>>>>> -L/ccs/proj/env003/petscv3.9-opt64-pgi/lib -lpetsc -lHYPRE -lflapack
>>>>> > /ccs/proj/env003/petscv3.9-opt64-pgi/lib/libpetsc.a(dlimpl.o): In
>>>>> > /autofs/nccs-svm1_home1/adams/petsc/src/sys/dll/dlimpl.c:53:
>>>>> warning: Using 'dlopen' in statically linked applications requires at
>>>>> > /ccs/proj/env003/petscv3.9-opt64-pgi/lib/libpetsc.a(send.o): In
>>>>> /autofs/nccs-svm1_home1/adams/petsc/src/sys/classes/viewer/impls/socket/send.c:101:
>>>>> > /bin/rm -f ex19.o
>>>>> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
>>>>> MPI process
>>>>> > [NID 18525] 2018-06-28 18:25:39 Exec ./ex19 failed: chdir
>>>>> file or directory
>>>>> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2
>>>>> MPI processes
>>>>> > [NID 18525] 2018-06-28 18:25:46 Exec ./ex19 failed: chdir
>>>>> file or directory
>>>>> > 1,5c1
>>>>> > < lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>>>>> > <   0 SNES Function norm 0.0406612
>>>>> > <   1 SNES Function norm 4.12227e-06
>>>>> > <   2 SNES Function norm 6.098e-11
>>>>> > < Number of SNES iterations = 2
>>>>> > > [NID 18525] 2018-06-28 18:25:55 Exec ./ex19 failed: chdir
>>>>> file or directory
>>>>> > Possible problem with ex19_hypre, diffs above
>>>>> > /ccs/home/adams/petsc/src/snes/examples/tutorials ex5f
>>>>> > ftn -c -fast  -mp   -I/ccs/proj/env003/petscv3.9-opt64-pgi/include
>>>>> -I/ccs/proj/env003/petscv3.9-opt64-pgi/include    -o ex5f.o ex5f.F90
>>>>> > PGF90-S-0155-Could not resolve generic procedure dmdacreate2d
>>>>> (ex5f.F90: 120)
>>>>> > PGF90-S-0450-Argument number 2 to snesgetiterationnumber: kind
>>>>> mismatch (ex5f.F90: 180)
>>>>> >   0 inform,   0 warnings,   2 severes, 0 fatal for main
>>>>> > PGF90-S-0155-Could not resolve generic procedure matsetvalueslocal
>>>>> (ex5f.F90: 464)
>>>>> (ex5f.F90: 477)
>>>>> >   0 inform,   0 warnings,   2 severes, 0 fatal for formjacobianlocal
>>>>> > gmake[3]: [ex5f.o] Error 2 (ignored)
>>>>> > ftn -fast  -mp  -o ex5f ex5f.o
>>>>> > /usr/bin/ld: cannot find ex5f.o: No such file or directory
>>>>> > /usr/bin/sha1sum: ex5f: No such file or directory
>>>>> > gmake[3]: [ex5f] Error 2 (ignored)
>>>>> > /bin/rm -f ex5f.o
>>>>> > Completed test examples
>>>>> > adams at titan-login6:~/petsc> ll
>>>>> > total 1864
>>>>> > -rw-rw-r-- 1 adams adams  11134 May  3 14:26 ex1.c
>>>>> > drwxr-xr-x 3 adams adams   4096 May  3 14:26 ex10d
>>>>> > -rw-rw-r-- 1 adams adams  92615 May  3 14:26 ex12.c
>>>>> > -rw-r--r-- 1 adams adams  19324 Jun 21 17:59 ex13.c
>>>>> > -rw-rw-r-- 1 adams adams  20550 May  3 14:26 ex14.c
>>>>> > <make.log><configure.log>
>>> Sent from Iphone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180630/0ca68bd9/attachment-0001.html>
