[petsc-dev] trying to make MKL work with GAMG
Mark Adams mfadams at lbl.gov
Fri Jul 6 16:26:42 CDT 2018
> Glad to hear that you got something (at least sort of) working, Mark. Let
> me know if you want me to work with your users on understanding the
> performance they are seeing. When I was working for Intel, I probably spent
> more time on dealing with stupid thread affinity settings than anything
> else when "optimizing" code performance.
That is a good idea. I will loop you into the thread.
> I should point out that, even with all of the thread settings correct, the
> current PETSc code base might not get much out of OpenMP threading with
> MKL. I'm assuming since you are using GAMG that a significant portion of
> time is spent in MatPtAP() operations? I'm not sure how much use of the
> sequential matrix-matrix multiply code the parallel MatPtAP() code can
> achieve.
The RAP or AP is in MKL right? I understand they have these sparse
matrix-matrix kernels. The get some reuse out of the RAP I think. I will
ask when I bring you in the thread (but I will wait for you to clarify what
is supported).
> There are some issues with mapping between the MKL interfaces for this and
> the PETSc ones, e.g., there is currently no equivalent of MatMultSymbolic()
> in MKL. I've had some discussions with the MKL team about this, but the
> current model they have isn't one that I can map all of the PETSc
> matrix-matrix interface onto. Hopefully I can get them to change this.
OK, I don't think it will be a problem in the near term ... and I don't
understand why there is no equivalent of MatMultSymbolic (setting up
communication maps?). How does if function without this. Please clarify!
> --Richard
>>>    Barry
>>> > On Wed, Jul 4, 2018 at 9:44 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> > On Wed, Jul 4, 2018 at 3:01 AM Richard Tran Mills <rtmills at anl.gov>
>>> wrote:
>>> > Hi Mark,
>>> > I'd never looked at the code for MatCreateMPIAIJWithSeqAIJ(), but it
>>> looks like if you are using MPIAIJ matrices but you've set
>>> "-mat_seqaij_type seqaijmkl",
>>> > No, I am using -mat_type aijmkl
>>> > then the "diagonal" portion of the MPIAIJ matrix ends up as a
>>> SEQAIJMKL instance, but the off-diagonal portion ends up as a plain SEQAIJ
>>> when it is created with MatCreateSeqAIJWithArrays(). (I have not stepped
>>> through this with a debugger to verify that this is actually what happens.)
>>> So, if we want the off-diagonal matrix to also be a SEQAIJMKL, then we
>>> either need to add some logic after the MatCreateSeqAIJWithArrays() call to
>>> check to see if a different subtype of SEQAIJ is being used and then
>>> convert it to the correct type, or we need a variant of
>>> MatCreateSeqAIJWithArrays() that will honor the subtype of SEQAIJ that we
>>> are using. Barry, since you added the concept of subtyping for SEQAIJ, what
>>> do you prefer?
>>> > No preference.
>>> > I note that in some (most?) cases, I think we are OK or even better
>>> off with the off-diagonal matrix in the MPIAIJ not being a SEQAIJMKL one,
>>> because the PETSc routines can used the "compressed row" stuff to speed up
>>> handling the many zero rows that often end up in the off-diagonal, whereas
>>> the MKL routines cannot.
>>> > OK , I'll keep that in mind. I pushed a branch with fixes to get my
>>> gamg tests working (ksp ex56 primarily). I'm going to make a new branch and
>>> try "-mat_seqaij_type seqaijmkl".
>>> > Thanks,
>>> > Mark
>>> > --Richard
>>> > On Tue, Jul 3, 2018 at 4:31 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > I have having to fix AIJ methods that don't get the type from the args
>>> to set created matrix type, so as to keep the MKL typing.
>>> > I am not sure how to fix this because I don't know to say 'make MPI
>>> from SEQ' in this method
>>> > PetscErrorCode MatCreateMPIAIJWithSeqAIJ(MPI_Comm comm,Mat A,Mat
>>> B,const PetscInt garray[],Mat *mat)
>>> >   ierr = MatCreate(comm,mat);CHKERRQ(ierr);
>>> >   ierr = MatGetSize(A,&m,&n);CHKERRQ(ierr);
>>> >   ierr = MatSetSizes(*mat,m,n,PETSC_DECIDE,N);CHKERRQ(ierr);
>>> >   ierr = MatSetType(*mat,MATMPIAIJ);CHKERRQ(ierr);
>>> > How should I do this?  Other places in the code I get the type from
>>> input (MPI) args and set created matrix types accordingly. I could just put
>>> a switch with an error for any new types that might come along in the
>>> future ...
>>> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180706/8fff8b89/attachment.html>
